Synlubes Posted December 4, 2006 Share Posted December 4, 2006 My question is for anyone using these and running 4+ degrees of positive caster. How much of the adjustment is used up? ie, how much tread is left showing after an adjustment with lots of positive caster. Quote Link to comment Share on other sites More sharing options...
bjhines Posted December 6, 2006 Share Posted December 6, 2006 I have not used them before.. But I will say that any double adjuster type of rod will adjust far more than any single adjuster type.... There are so many variables here that you need to take it to an alignment shop and then modify the piece if it does not work... Ususally you can order a longer threaded tube for about $15... Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 6, 2006 Share Posted December 6, 2006 bjhines said: Ususally you can order a longer threaded tube for about $15... Yep. If it is a 5/8" turnbuckle you can order a swaged steel or an aluminum replacement turnbuckle in just about any length you want from http://www.colemanracing.com. Quote Link to comment Share on other sites More sharing options...
