gexgexgexgex Posted December 20, 2006 Share Posted December 20, 2006 I am getting my LT-1 ready to install into my 240z. I was putting the oil pan back on and i was 100% sure the bolts should be at 18 foot pounds, so i get it all tight and ready. I then start to double check somethings and find out the oil pan bold should have been set to 8 foot pounds. So did i just kill my new $30 oil pan gasket, or will it be ok and should not leak? Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 20, 2006 Share Posted December 20, 2006 18lbs isn't much... I really REALLY doubt you did any damage to the gasket. Quote Link to comment Share on other sites More sharing options...
gexgexgexgex Posted December 20, 2006 Author Share Posted December 20, 2006 so should i leave it at 18 pounds or take it back down to 8 Quote Link to comment Share on other sites More sharing options...
80LS1T Posted December 20, 2006 Share Posted December 20, 2006 You should be fine where you are. They are all even so you shold be fine. Like Nismopick said, 18 ft-lbs really isn't much even when compared to 8 ft-lbs. Quote Link to comment Share on other sites More sharing options...
gexgexgexgex Posted December 20, 2006 Author Share Posted December 20, 2006 u guys always rule thanks a bunch Quote Link to comment Share on other sites More sharing options...
schwiplarkin Posted December 21, 2006 Share Posted December 21, 2006 what ever you do dont loosen the bolts, you have already compressed the gasket , if you loosen it it will leak! Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted December 21, 2006 Share Posted December 21, 2006 What type of gasket is it? Quote Link to comment Share on other sites More sharing options...
gexgexgexgex Posted December 21, 2006 Author Share Posted December 21, 2006 the gasket is all rubber with little round metal parts round each bolt hole. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 21, 2006 Share Posted December 21, 2006 the gasket is all rubber with little round metal parts round each bolt hole. Then it won't matter a hill of beans. The metal shims keep the distance constant between the pan and the block. You can safely back that off to 8 lbs if you want, but it shouldn't make a difference either way frankly with the quality parts you have. If this was a gasket without the shims (ie cork gasket) then that's a different story. Davy Quote Link to comment Share on other sites More sharing options...
