injector pulse
260zturbo
Do you have +12v on one pin of the injector? Do you have resistors in series with the second injector pin and the MS? How do you have the injectors wired (3 in parallel on each injector driver)? Have you tested your MS on a stim?
Even more importantly on a car that cranks but does not fire....do you have spark as well?
You are not tromping on the pedal while cranking (giving the 'flood clear' signal inadvertently)...
Pulsewidth showing doesn't mean it's enough to fire the engine, especially if there is no spark on the plugs....
Do you see your fuel pressue fluctuate at all while cranking? Usually the bogger pulsewidth batch fire on simultaneous will draw down the fuel pressure enough to see it. If you don't see fluctuations, you may indeed not have injection events happening, but you have to also verify spark...
Is the Injector LED on the MS Box flashing, indicating the MS is sending an initiation pulse to the injectors? If it's not, then there may be something internal to the MS. If it is, then it may be external between the box and the injectors.
Just because you read it on the MT, doesn't mean it's actually physically connected and cycling the injectors.
