MAP sensor location Q
MAP measures presssure, every application I've seen mounts the map either inside the ECU or on the fender or firewall.
Where you get the signal from needs to be after the throttle, or if using ITBs preferably on the balance tube.
The SDS website (http://www.sdsefi.com) has some really good tech articles. Their installation manual (http://www.sdsefi.com/em4main14.pdf) talks about mounting a MAP sensor on page 10.
