LC 1 widband
kvansic162
What should the LC 1 wide band voltage read in the enrichments? Mine says 2.509.
im guessing 2.5, since anything below half of the max 5 volts is seen as a below median, and anything above the 2.5 volts is seen as above median.
0 being max low
2.5 being mid-point
5 being max high
if you started at 0 volts, there would be no way for it to give you an accurate below-median reading.
Just fired off a MS with an LC1 running SU Carbs, and it was idling at 1.68!
Actually, it was revving at 1.68 as well...
With EGT's in the 1400 range going down the road.
The owner swears he will "get the SU's running correctly" and I laughed. I told him for the effort, he can install his injectors and have the MS drive them, and that will be easier than getting his SU's to work correctly!!!
on this note..
I am trying to hook up the Innovate LC1 to the Megasquirt unit...
If i hook up the wiring directly MS reads the proper AFR according to my guage..
but I am supposed to install an in-line 1/4watt 1k resistor?!
Well with the resistor inline.. Its all screwy and the readings are WAY off
** EDIT - ahh.. i need a 1/4 watt 470 ohm! not 1k!
