gretchen/jason Posted January 27, 2007 Share Posted January 27, 2007 My 350 block has holes for 2 dip stick tubes . Does anyone know what size freez plug or something i could get to plug the hole with . I atempted to try to use a dip stick but couldnt get a acurate fit . Jason Quote Link to comment Share on other sites More sharing options...
lbhsbZ Posted January 28, 2007 Share Posted January 28, 2007 measure the hole? Quote Link to comment Share on other sites More sharing options...
Forces Posted January 28, 2007 Share Posted January 28, 2007 My buddy switched oil pans to a 7 qt Mildon, I believe, which has that hole for the dipstick right in the pan. I think he used Belzona to plug the hole. It's kinda like JB weld, but 10 times better. I think the NAVY uses it to patch cracks in their ships. two compounds that, when mixed together, dry up hard as steel. Seann Quote Link to comment Share on other sites More sharing options...
jbk240z Posted January 28, 2007 Share Posted January 28, 2007 Just go to your local PepBoys or Napa or other? They have an assortment of freeze plugs individually packaged. Bring your dipstick tube to ensure you get the proper size. Good luck. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted January 28, 2007 Share Posted January 28, 2007 I have use a 3/8 bolt with permatex before, that is if the dip stick tube is out of the block. John Quote Link to comment Share on other sites More sharing options...
gretchen/jason Posted January 28, 2007 Author Share Posted January 28, 2007 The bolt and permatex idea sounds good as the hole is really hard to get to i can barley get to it with one finger . To bad i didnt see it before i installed the engine . i only noticed it after i romped on itone day and saw oil spitting everywhere !!! Jason Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted January 28, 2007 Share Posted January 28, 2007 Spray some ether around the hole and some inside, than let air dry or blow with some air. The ether will evaporate quickly, Apply a genorus amount of permatex, usual same engine color to blot threads and push it in the hole, do not aplly at bottom of bolt, you want to keep the permatex out of the engine. Then I would let dry at least 24hrs if not longer. John Quote Link to comment Share on other sites More sharing options...
endurorider Posted February 4, 2007 Share Posted February 4, 2007 go to your chevy dealer and tell them you have a target master block and need the cap for the dipstick tube. they should be able to fix you up. They do those blocks a-b blocks to fit a wide range of applications. I have installed a few. you could run two dipstick tubes and freak peop;le out he hehe Quote Link to comment Share on other sites More sharing options...
endurorider Posted February 4, 2007 Share Posted February 4, 2007 i dont think youll find a frezze plug that small and i dont like the idle that it could find its way in your oil pan. you could get a wrecking yard tube cut it down crimp it and put silicon on it. Quote Link to comment Share on other sites More sharing options...
endurorider Posted February 4, 2007 Share Posted February 4, 2007 sorry to hijack but, Jason, is that a 144 weinand blower . if so would like to see more photos. hows hood clearance.? Im sure you need a 4 inch cowl min. is that enough? Quote Link to comment Share on other sites More sharing options...
