driftz240 Posted February 11, 2007 Share Posted February 11, 2007 The racks look simular in a pic i have, other than the whole manual and power difference. has anyone ever put a s13 rack into a s30 to try to get more steering angle, or power steering? Quote Link to comment Share on other sites More sharing options...
vashonz Posted February 11, 2007 Share Posted February 11, 2007 To get more steering angle you will first need to solve the problem of the wheel running into the TC rod and frame rail (or sway bar) Quote Link to comment Share on other sites More sharing options...
driftz240 Posted February 12, 2007 Author Share Posted February 12, 2007 yeah i have taken care of that, i have a modified stock rack, i cut more teeth into , and removed the spacers. but i want way more angle... its for a drift car. the modified rack is good, and greatly increased the turning radius and steering angle of the car, i still have less angle than some of the s13/14's out there at the track. will the motorsport steering knucles add anything more angle? Quote Link to comment Share on other sites More sharing options...
Careless Posted February 17, 2007 Share Posted February 17, 2007 driftz240 said: yeah i have taken care of that, i have a modified stock rack, i cut more teeth into , and removed the spacers. but i want way more angle... its for a drift car. the modified rack is good, and greatly increased the turning radius and steering angle of the car, i still have less angle than some of the s13/14's out there at the track. will the motorsport steering knucles add anything more angle? can you post pics of whta you've done, please? Quote Link to comment Share on other sites More sharing options...
driftz240 Posted February 18, 2007 Author Share Posted February 18, 2007 you cant see what i did to the rack, i disassembled it and cut 2 more teeth into the rod. and simpily removed the bushings, and trimmed the ends of teh rack housing 1/2 each side so on the car it just looks like a normal rack. I still want more angle, I think if i could fix this problem it would be competitive on a professional level. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 19, 2007 Share Posted February 19, 2007 If there is nothing in the way shorter steering arms will give you more turn angle. Pics of drift car? Quote Link to comment Share on other sites More sharing options...
KAZU Posted February 19, 2007 Share Posted February 19, 2007 S13 rack into S30? You steer right, the car turn left. S13 rack is located behind LCA. Quote Link to comment Share on other sites More sharing options...
driftz240 Posted February 21, 2007 Author Share Posted February 21, 2007 im talking about mounting and modifing it to fit where the stock z rack fits, i have only seen a picture of the rack and it looks simular, and i know it has more throw than the z rack, and i can use stronger tie rods than the z cars. why would it turn the wrong way again? Quote Link to comment Share on other sites More sharing options...
viperredls1z Posted February 22, 2007 Share Posted February 22, 2007 on a front steer car like our s30's the pinion is under the rack, so when you turn right the rack moves to the right. if you use a rear steer rack the pinion is on top of the rack and it will cause the wheels to turn the wrong direction if the rack is mounted in front. Quote Link to comment Share on other sites More sharing options...
driftz240 Posted February 23, 2007 Author Share Posted February 23, 2007 ahhhh, good to know i think the shorter steering arms is about all i will be able to do, it has alot of steering angle, but im looking for that last little bit, the difference in hitting the steering lock mid drift and thinking oh crap i thought i had more steering, or pulling out of a big angle drift i like the arizona z car ones with built in rca's those look nice. thats probably what im gonna get. Quote Link to comment Share on other sites More sharing options...
Careless Posted February 23, 2007 Share Posted February 23, 2007 viperredls1z said: on a front steer car like our s30's the pinion is under the rack, so when you turn right the rack moves to the right. if you use a rear steer rack the pinion is on top of the rack and it will cause the wheels to turn the wrong direction if the rack is mounted in front. so mounting it underneath or mounting it on it's stock crossmember would work though, right? Quote Link to comment Share on other sites More sharing options...
viperredls1z Posted February 23, 2007 Share Posted February 23, 2007 No, but there are plenty of other front steer power racks that are a lot easier to install, and there fairly cheep. Mine is a 99 subaru impreza rack that I got for $100.00 at a J yard. Quote Link to comment Share on other sites More sharing options...
Careless Posted February 23, 2007 Share Posted February 23, 2007 viperredls1z said: No, but there are plenty of other front steer power racks that are a lot easier to install, and there fairly cheep. Mine is a 99 subaru impreza rack that I got for $100.00 at a J yard. sorry. just to clarify, by "its stock crossmember" i meant using the s13's cross member and mounting it on THAT crossmember's stock location. that wouldnt work? what about s14? Quote Link to comment Share on other sites More sharing options...
viperredls1z Posted February 23, 2007 Share Posted February 23, 2007 Yes that would work steering wise, but I don't think it's a practical solution to this problem, the track is wider and geting the struts in the correct location may prove impossible. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted February 26, 2007 Share Posted February 26, 2007 Careless said: sorry. just to clarify, by "its stock crossmember" i meant using the s13's cross member and mounting it on THAT crossmember's stock location. that wouldnt work? what about s14? I would think that you would have to graph the whole s13 suspension/spindle as well. Quote Link to comment Share on other sites More sharing options...
driftz240 Posted March 2, 2007 Author Share Posted March 2, 2007 why switch to the sube rack, is it faster, more angle????? more info, im interested Quote Link to comment Share on other sites More sharing options...
viperredls1z Posted March 2, 2007 Share Posted March 2, 2007 Yes, it is a little faster. and it has more travel. (travel = angle) as long as you have wheel clearence. wheel clearance is going to be your limiting factor. Quote Link to comment Share on other sites More sharing options...
Careless Posted March 2, 2007 Share Posted March 2, 2007 viperredls1z said: Yes that would work steering wise, but I don't think it's a practical solution to this problem, the track is wider and geting the struts in the correct location may prove impossible. hehe.. i like wide =) nothing a little improvisation can't fix Quote Link to comment Share on other sites More sharing options...
AK-Z Posted March 4, 2007 Share Posted March 4, 2007 Hey. I was thinking. Would a s13 rack to work on a 280zx. Isn't the stock rack loacated located behind the xmember? Quote Link to comment Share on other sites More sharing options...
