JustinOlson Posted February 24, 2007 Share Posted February 24, 2007 Would weld in camber plates help lower the front down? Justin Quote Link to comment Share on other sites More sharing options...
stony Posted February 24, 2007 Author Share Posted February 24, 2007 Nope the camber plates help adjust camber and get mounted in teh same location as the stock upper shock mount. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted February 24, 2007 Share Posted February 24, 2007 Actually camber plates will lower the front because they get rid of the large rubber insulator. Probably drop it 1" to 1.5". If you add or subtract BELOW the spindle, like with bumpsteer spacers, then it has no effect on ride height. Add or subtract ABOVE the spindle, like eliminating the insulator or sectioning the strut, and it does affect ride height. Basically from the ground to the spindle the size of the wheel determines the height, and from the spindle up the suspension lengths and all that determine the distance from the spindle to the body of the car. Quote Link to comment Share on other sites More sharing options...
stony Posted February 24, 2007 Author Share Posted February 24, 2007 Roger that, forgot about those pesky rubber things Quote Link to comment Share on other sites More sharing options...
