bobbyc Posted February 13, 2007 Share Posted February 13, 2007 my 2 flanges came in today...i'm gonna make a spacer for the hx35...now i just need to know how i should make it...i have a couple rough drawings...was wondering if one design would be better over the other here are the 2...if i do it straight..it's prob gonna hit the strut tower..round thing is the turbo Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted February 13, 2007 Share Posted February 13, 2007 The bottom option should work best Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 13, 2007 Author Share Posted February 13, 2007 k...what about the flange and the piece between...the round edges on the flange...should i really owrry about the piece in the middle there having the round edges to follow the flange or does that matter? Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted February 13, 2007 Share Posted February 13, 2007 i'm going to be using a flange similar to that, but it has 2 sets of holes. 1 set to bolt up to a t4 style flange and then a set for a t3 style turbo to bolt up to the flange. Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 13, 2007 Author Share Posted February 13, 2007 hmm..that's an idea...i can tap the other falnge so i can just bolt it on...but putting a nut on the other side wouldn't be that hard either....we will see...i'm workin on it now..trying to figure out what i can come up with Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted February 13, 2007 Share Posted February 13, 2007 are you planning on running an external wastegate? Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 13, 2007 Author Share Posted February 13, 2007 later i will....for now i'm just gonna use the one on it Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 13, 2007 Author Share Posted February 13, 2007 i made it shorter and didn't angle...made some progress...now i just have to cut the steel and fill in the sections between...make sure it's flush and weld it up...i can easily break it off from the flanges...i'll then clean it up and weld it all togetheri like it so far...comin along pretty good...it'll look tons better once i take a flapper to it and make it all pretty later on i can take it off and add on some pipe for an external wastegate...but for now i think this will work. i took pipe and sectioned it so i could get the curves on the inside to match up...cause they match up with the manifold... Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted February 14, 2007 Share Posted February 14, 2007 Bobby C. said: later i will....for now i'm just gonna use the one on it then, for now that'll be fine. but when you decide your ready to run an external wastegate the adapter with the bend will be best, mount the WG at the corner of the bend so the WG gets a better flow. check out maximum boost by corky bell, books amazing Quote Link to comment Share on other sites More sharing options...
blake culp Posted February 14, 2007 Share Posted February 14, 2007 The piece looks pretty good. You proabbly already checked for clearance issues but make sure the turbo will clear the steering shaft. I tried to make a spacer almost identical to yours but like mentioned above i was also going to weld a piece of pipe out the bottom for the my external wastegate. Finally gave up on it because i just couldn't get my turbo to clear the steering shaft, but i have a zx. I know 240's have a different steering shaft and more room than a zx. Just a word of caution. Blake Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 14, 2007 Author Share Posted February 14, 2007 here it is...gettin close to completion...my digital camera broke so i have to take em with my phone...pretty crappy...but it's look pretty good...i think it's gonna do well...it clears everything also Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 14, 2007 Author Share Posted February 14, 2007 all finished i have about an inch between the steering shaft and turbo Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 14, 2007 Author Share Posted February 14, 2007 well it's done and on.... Quote Link to comment Share on other sites More sharing options...
mikeatrpi Posted February 14, 2007 Share Posted February 14, 2007 That's pretty swift. You do good work. What kind of turbo is that? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 15, 2007 Share Posted February 15, 2007 as mentioned.. Holset HX35 good work Bobby Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted February 15, 2007 Share Posted February 15, 2007 I did a nice thing and took your super dark pic and made it a lil more visible to see what's going on... good job on the fab work. Ubber close to the fender wall now though. Quote Link to comment Share on other sites More sharing options...
bobbyc Posted February 15, 2007 Author Share Posted February 15, 2007 thanks....the cold side is actually gonna be adjusted...the wastegate is acutally gonna run under the IC piping...i'll take pics tomorrow...i re-clocked it tongiht...but the spacer actually gave me more room to play with it...should work out pretty nice Quote Link to comment Share on other sites More sharing options...
mikeatrpi Posted February 15, 2007 Share Posted February 15, 2007 Sorry I didn't realize "hx35" meant "Holset". Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 16, 2007 Share Posted February 16, 2007 sorry Quote Link to comment Share on other sites More sharing options...
