They have to be 4x4.5" bolt pattern to fit on a Z...
They need to be set up with Z car specific(lugcentric) spacers to arrive at ZERO offset...
You are not likely to get anything wider than a 225 between the strut and the wheelwell...
The Z car uses LUG-CENTRIC mounting... that means that the lugs are the only things centering the wheels on the hubs... that means the spacers must be CAREFULLY CHOSEN to avoid failure of the lug studs... DO NOT USE AUTO PARTS STORE SLOTTED SPACERS... and obviously you cannot stack spacers to get the right thickness....
they wont work for the 510 or for 240sx crowed. the rims looks like some kinda of cheapo eagle rims. im kinda lost here though, you said made by rota and then you ask you need help to id the rims? if you are asking for discription, lets just say, chrome star rims made by rota. i cant think of a datsun that came with 4x100...anyone???
If they came off a 510 the bolt pattern is 4x100, unless he used an adapter.
240sx, 240z, 510 all use the same (4x114.3) bolt pattern.
Rotas are generally considered to be cheap, heavy, weak, and unreliable. To the point where there are t-shirts saying "Friends don't let friends roll on Rotas"
I doubt you will get much interest from anyone with a 240sx when you try to sell them.
