rear poly bushing problem
Guys,
I just bought the poly bushing kit. What is your trick to get the rear control arm mated to the strut. I can't seem to compress them enough to enter the strut. I have search, but didn't find anything about it.
Thanks guys, I quite feel dumb on that one.
Dayz
I used a C-clamp to compress the bushing, then levered the strut in which pushed the C-clamp off. It wasn't pretty, but it worked. Did you look at putting zerk fittings on the outer ends of the control arm? I think that is well worth the time and effort. Those outer bushings are SO tight, if they're going to squeak, its going to come from there.
Here's a pic:
