vss speedo ?
Hey I have a quick question....i installed a 40 pulse vss on my 4l60E lt1 combo. I am getting good voltage from my VSS into the PCM (put the car on stands and put it in gear) but the out to speedo wire (D8 i believe) just sits at .5 volt ac no matter how fast my wheels spin. So, i checked to make sure that its programmed right and everything checked out. So then i just wired straight from the VSS to the Speedo and everything worked fine. My speedo is an autometer. Its like the PCM out to speedo isn't sending the right signal? Do most of yall just run the speedo right off the VSS? thanks!
