SSflyer Posted February 25, 2007 Share Posted February 25, 2007 Is it normal for new coilover springs to keep settling. I mounted mine per the instructions (on the rear) and set them to a good ride height, and reset them again last week, but now the car has settled back to almost the same height as before. I'm wondering if I should move the sleeve up some. The adjusting screw is about 3/4" from the top of the sleeve and I still need to gain a little more clearance. If so, does anyone have an extra pair of mounting rings they'd like to sell? (The coilover kit came from Modern Motorsports and has 10" springs). Quote Link to comment Share on other sites More sharing options...
aziza z Posted March 28, 2007 Share Posted March 28, 2007 did you ever find out why it was doing that? Quote Link to comment Share on other sites More sharing options...
johnc Posted March 28, 2007 Share Posted March 28, 2007 Is the adjustable lower spring perch loosening (turning down)? It should have a set screw that you snug down to keep it from turning. Quote Link to comment Share on other sites More sharing options...
evildky Posted March 31, 2007 Share Posted March 31, 2007 you could always run 12" springs Quote Link to comment Share on other sites More sharing options...
SSflyer Posted March 31, 2007 Author Share Posted March 31, 2007 Never did figure this out, so instead I moved the perch rings up an inch, so the sleeve is right to the top of the strut tube, and started adjusting again. I seem to have found the spot where the body lifts, but it takes some muscle on the spanner to turn the adjusting ring. Now there's no more rubbing and the ride is still ok, bit it took 4 or 5 adjustments to get it to where it is. Quote Link to comment Share on other sites More sharing options...
srgunz Posted March 31, 2007 Share Posted March 31, 2007 You should definately send a photo to MM of the spring gap remaining with the car sitting on the ground after a drive. To me the springs are very suspect. If they bind on compression, well, thats not good at all. Quote Link to comment Share on other sites More sharing options...
