CalifaThugz Posted March 10, 2007 Share Posted March 10, 2007 Hey I'm going to paint my new Z and whats best primer to use and how much primer will I need and about how much will it cost? Quote Link to comment Share on other sites More sharing options...
GEMINITWIN111 Posted March 10, 2007 Share Posted March 10, 2007 urethane primer(pic your brand).youll need about a gallon.it runs about $100 a gallon with reducer and hardener Quote Link to comment Share on other sites More sharing options...
CalifaThugz Posted March 10, 2007 Author Share Posted March 10, 2007 Thanks I'm going to need to get a compressor and a spray gun as well... around 500 for both right? Quote Link to comment Share on other sites More sharing options...
GEMINITWIN111 Posted March 10, 2007 Share Posted March 10, 2007 you don't need that nice of a gun to spray primer.a 6 gallon compressor is enough for one gun. Quote Link to comment Share on other sites More sharing options...
Two40MuscleZ Posted March 10, 2007 Share Posted March 10, 2007 There are a lot of considerations; even when it comes to primering! Depending on what you are using the car for i.e. daily driver or show constitutes your final finish. A self leveling Catalized Poly Urathane primer is by far the best. Depending on the amount of body repairs completed and how good it is will regulate the amount of primer required. Usually for a daily driver a gallon should be enough. However, if extensive work has been applied then as much as 2 gallons or more can be necessary. If you are building it up for show, plan on minimum 2, if its black then your looking at 3 gals. In SoCal, you can pick a gallon up for $55 - $85 which includes the catalyst. Guns are another story. Just remember you get what you pay for. And the quality of the finish goes hand and hand with that. Unless you are going to do a considerable amount of painting and your not shooting Candys, Pearls or Flake, then your "Primer" gun range should be somewhere around $85 -$135. You can find cheeper guns but the finish will not be the same. Your color and top coat guns again depends on the type of finish paint you'll be shooting. You can pick up a decent color gun for $150 and up. Good finish guns are $400 - $800. There are other posts in the Hybrid archieves regarding spray guns and various types. The compressor...the bigger the better as far as continual air usage and convenience of use. A small compressor will be slow to rebuild the pressure, and not hold a constant fan pattern. Also, a smaller compressor will continually run trying to rebuild the expended air. Water build up in the smaller compressors are a real problem, and you will have to buy a water trap/pressure regulator. Lots of little Gremlins to mess with. Its not just pouring some paint you picked up in a gun and start shooting. Do your research, do some practice areas and then try your hand at repainting your ride. Don't even mess with the Candies and/or Pearls until you have practiced abit with solid colors. Some of those cool Candy and Pearl colors can run as high as, $1,100.00+ a gallon. Camelion Colors are minimum $500 a quart! Good luck with your project. VAN Quote Link to comment Share on other sites More sharing options...
CalifaThugz Posted March 10, 2007 Author Share Posted March 10, 2007 Thanks! I don't know how many gallos my compressor is but if I have to I'll get a diffrent bigger one. But yea I'm just going to leave it black primer for about a month or two sand it down again afterwards and paint it metallic blue I've seen it on a lot of Z's they look clean. Quote Link to comment Share on other sites More sharing options...
wickiewicked240z Posted March 11, 2007 Share Posted March 11, 2007 meza body supplies were i got my epoxy primer PPG epoxy primer DP50LF 1 gallon_$126.90 PPG Epoxy primer Catalyst 2x$37.80_$75.60 Quote Link to comment Share on other sites More sharing options...
Two40MuscleZ Posted March 11, 2007 Share Posted March 11, 2007 The pricing structure varies depending on your geographic location. The SFO bay area cost of living index is slightly higher than here in SoCal. My cost index for supplies and materials is lower than many because I have been in the business painting custom cars for 37 years; and have delt with the same paint dist. the entire time. So, they graciously give me a break on materials and tools purchased from them. In any event, purchase quality materials and equipment and the end results will be just that...quality! Van Quote Link to comment Share on other sites More sharing options...
GEMINITWIN111 Posted March 11, 2007 Share Posted March 11, 2007 paint products here in texas are dirt cheap.i use sikkens and have been very satisfied with them other than there clear is a little soft. Quote Link to comment Share on other sites More sharing options...
