MY77Z Posted March 13, 2007 Share Posted March 13, 2007 hi guys, well i've never seen a 351w block before, and not really sure what trucks they came in, so if any body could kindly tell me what year/model they came in and how to identify a 351w block because i think we have alot of them in our ford junk yards here in Kuwait.....the 351 is not for my Z, its for my engineless mustang thanks Quote Link to comment Share on other sites More sharing options...
TomsCoupe Posted March 14, 2007 Share Posted March 14, 2007 351c or 351w? i didnt know the 351c came in trucks. 351c link http://home.comcast.net/~jelerath/mustang/Specs/specs-fr.html Quote Link to comment Share on other sites More sharing options...
MY77Z Posted March 14, 2007 Author Share Posted March 14, 2007 my bad a 351W is what i'm lookin for.........but which one is better ?? a W or C block ? Quote Link to comment Share on other sites More sharing options...
Paz8 Posted March 14, 2007 Share Posted March 14, 2007 351 windsor engine block casting numbers 1971-74, D2AE-BA 6015. 1975-84, D4AE-DA. The 351W looks like a 302. Many trucks had a different 351 called a 351M, stay away from the M motors. Hope that helps some. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted March 14, 2007 Author Share Posted March 14, 2007 the codes help alot, thanks, but how to make the difference between the M and the W blocks? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 14, 2007 Share Posted March 14, 2007 It will be almost indistiquishable from the block you put in your Z with the exception of larger main caps (not visible unless oil pan is off), and the block being slightly wider and toller. It's just a puffed up version of a 302 basically (uses same type of timing cover, bellhousing, and heads.) The M blocks are puffed up Cleveland motors and will have a different timing cover and heads. Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted March 14, 2007 Share Posted March 14, 2007 If I'm not mistaken, the Cleveland timing cover is a flat plate. The block is built out and timg chain is recessed in. Then the fuel pump bolts are straight up and down, instead of cross ways like the 289's/early 302's. The water pump looks the same. Quote Link to comment Share on other sites More sharing options...
Trevor Posted March 14, 2007 Share Posted March 14, 2007 Challenge my memory here, I think 351 Cleveland has the upper radiator hose coming from the block, not the front of the intake manifold. The 351W is like the 302, the radiator hose comes off the thermostat housing on the front of the intake manifold. This makes them easy to spot in the JY. ^^ 351C Torino / Mustang intake ^^ Quote Link to comment Share on other sites More sharing options...
TomsCoupe Posted March 15, 2007 Share Posted March 15, 2007 Dont forget about the physical size difference of the 351c and 351m(destroked 400). they are MUCH bigger than the 351w. the 351w has a huge aftermarket because you can bolt most 302 parts on it, the 351c is the complete opposite. The aftermarket scene for 351c isnt nearly what it is for th 351w. so keep that in mind when choosing. C being Cleveland, W being Windsor. In case someone didn't know. Quote Link to comment Share on other sites More sharing options...
Paz8 Posted March 15, 2007 Share Posted March 15, 2007 I think that ford only built 351 C's from 1970 to 1974, chances of finding one are slim, the magic in these engines was the heads with very large valves, and NO the heads won't fit a 351W. Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted March 15, 2007 Share Posted March 15, 2007 The heads will bolt on 351W and 302 blocks. They have the same bolt pattern. But you have to modify them to work. Thats how you get the Clevor. Check this article out, it shows and tells how and what you need to do it. http://mustangandfords.com/techarticles/30220_clevor_engine/ Quote Link to comment Share on other sites More sharing options...
Zerrari GTO Posted March 15, 2007 Share Posted March 15, 2007 LMoore56 said: The heads will bolt on 351W and 302 blocks. They have the same bolt pattern. But you have to modify them to work. Thats how you get the Clevor. Check this article out, it shows and tells how and what you need to do it.http://mustangandfords.com/techarticles/30220_clevor_engine/ Yep, that's basically what a 69'-70' BOSS 302 is; a 302 with 351 Cleveland heads. Quite a few people have put 2V or 4V 351C heads on a 302 to make their own versions. Modern aftermarket 351W heads flow better than the Cleveland heads and as posted above, the aftermarket for Windsor motors is MUCH better. Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted March 15, 2007 Share Posted March 15, 2007 Also, check this kit out at the Mustang Depot at eBay It has a little less than 8 days left, then the link more than likely won't work. http://cgi.ebay.com/ebaymotors/CLEVOR-CLEVELAND-FORD-Stroker-Kit-351-MUSTANG-COBRA-TMD_W0QQcmdZViewItemQQcategoryZ33620QQitemZ180096033216 Quote Link to comment Share on other sites More sharing options...
