Ivan280zt Posted March 29, 2007 Share Posted March 29, 2007 F@#K!!! I have nothing else to say : ) Ivo Quote Link to comment Share on other sites More sharing options...
ktm Posted March 30, 2007 Share Posted March 30, 2007 I see that many have beat me to the line for the center console. I had visions of doing the same (console) for my car. Amazing vision and execution. Quote Link to comment Share on other sites More sharing options...
zdream Posted March 30, 2007 Author Share Posted March 30, 2007 The Intercooler has now got plates welded around it to try and make it more efficient. gone is the surge tank and lifter pump and in its place is a fuel cooler on the return line to the tank.The fuel lines from the tank to the pump are now16mm ID (5/8) Quote Link to comment Share on other sites More sharing options...
zdream Posted March 30, 2007 Author Share Posted March 30, 2007 Quote Link to comment Share on other sites More sharing options...
mtcookson Posted March 30, 2007 Share Posted March 30, 2007 I actually just saw stuff about fuel coolers yesterday. You probably didn't do a before and and after but I figure I'd ask, notice any difference? Makes sense that it would, just never really heard about them being used all that often. I'll probably be giving one a try but wanted to get some opinions on them. Thanks! Quote Link to comment Share on other sites More sharing options...
zdream Posted March 30, 2007 Author Share Posted March 30, 2007 Having so much motor in a small engine bay causes a lot of heat, and the fuel picks this heat up and moves it back to the fuel tank.On the dyno my fuel would get so hot we would have to let the car rest for a while to cool down.The fuel pump would become noisy and struggle moving the fuel.Having one less pump for it to travel pass could only help with less heat and placing a cooler on the return line has got to work So far the pump does not get noise when driving,so it has to be pulling a lot of heat out of the fuel:smile: Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 31, 2007 Share Posted March 31, 2007 Is your fuel rail dead ended? Do you have a good size return line (3/8" or bigger)? This should be enough to keep the fuel cool. Filling up before your dyno session will give you more thermal mass in the tank. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 31, 2007 Share Posted March 31, 2007 That must be a fun car to have a little good time in! Quote Link to comment Share on other sites More sharing options...
zdream Posted March 31, 2007 Author Share Posted March 31, 2007 Is your fuel rail dead ended? Do you have a good size return line (3/8" or bigger)? This should be enough to keep the fuel cool. Filling up before your dyno session will give you more thermal mass in the tank. Yes the fuel rails are dead end which I am going to change. I did this to try and keep the lines and rails to a minimum in the engine bay to avoid heat soak in the fuel, There is so much pipe work in the bay it is hard to keep anything cool in there.But in saying that the engine does not run hot.The exhausts pipes have been coated and dump pipe wraped in heat wrap.Took it for a drive saturday and the pump did not run hot and noisy:D the cooler is helping:razz: Quote Link to comment Share on other sites More sharing options...
zdream Posted April 7, 2007 Author Share Posted April 7, 2007 NO brakes need here Just stomp on the gas 1st,2nd,3rd Quote Link to comment Share on other sites More sharing options...
Guest Denzo Posted April 17, 2007 Share Posted April 17, 2007 that thing is ridiculous! and I mean that in the very best way possible i want one Quote Link to comment Share on other sites More sharing options...
tannji Posted April 17, 2007 Share Posted April 17, 2007 Jeeez.... there is no way putting the hood back on would make that car look any better... I vote to leave appearances as is... sick, sick, sick! Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted April 17, 2007 Share Posted April 17, 2007 Sweet... Quote Link to comment Share on other sites More sharing options...
