280zcar's 78 280z LS1/T56
Done with everything to do with fuel system except wiring the fuel pump.
Hatch and taillights put back on as well.
Seam sealed and painted.
Starting to look like a car again... need to get flip down license plate bracket still
Haven't done much with the engine bay.. going to try and get it mostly finished up this week and then hopefully to my friend to paint it in the next week or two. While its off to paint, I'm going to bring in the donor vehicle and yank the engine and trans out of it.
Edited by 280zcar
  • 3 weeks later...
  • Replies 196
  • Created
  • Last Reply
Top Posters In This Topic
wet sanding.
found a couple small things that i need to touch u,p but all-in-all it looks pretty decent so far.
Scheduled to get it in my friends booth early next week and while its there I'll bring in the donor and pull the engine/trans.
Bringing the Z back from paint.
Pushed it up in to the garage.
Engine in new home. Working on getting some stuff mocked. Found out i need to slot the holes for the mounts a little more...
I'll have to borrow a camera to get some better pics sometime... my cell camera is lacking.
Engine going back in after bolting up transmission
Shifter placement couldn't have been better. This was kind of lucky since i never mocked up the engine with my mounts with a t56.
Alternator mounted and clearance looks good.
Bolted radiator in. Upper hose is going to be close. Might just try and chop up f-body hose and splice it.
Lower hose fits perfectly
overview
Thanks, Me too....
JTR Intake piping done. Just need filter and a couple more clamps.
PCM mounted.
Fuse block mounted up on the pedal box.
Passenger manifold mocked up. Needs to be full welded still. Bascially just chopped off the flange and welded on an extension. Waiting for drivers manifold to ship in... its going to get some similar cutting done. Already made new passenger front brake line that will go along the top to the frame rail. Rear brake line will just be bent out of the way of the exhaust
Edited by 280zcar
Chassis wiring reconnected
New brake line bent
New front fender. It needs a little bit of body work, but virtually no rust.
Fan wiring done. ECM will control the Taurus fan with this Volvo
seam sealer
Starter and alternator wiring are done.Still working on where I am going to mount battery. Cable to the left is just for hooking to battery to test things.
Drive shaft is in.
Heater lines blocked off.
Drilled new hole on throttle bracket so the cable has a straighter shot at the throttle
Rubber shift boot installed
Dash is back in.
Driver's brake reinstalled
Upper Radiator hose
Steam vent routed to water pump
Edited by 280zcar
Kevin, I initially was rigging something up with a small agm in the passenger footwell against the firewall, but didn't like it and placed a full size agm battery behind passenger seat in front of toolbox. The passenger seat does not slide all the way back, but far enough to give ok legroom for me and I'm about 5"11. It took about 8-9 ft of battery cable, but it works. Battery is inside the cabin, but it's a sealed agm for now so I think it should be okay. I'm not at any sanctioned track events yet.
I just ordered a Odyssey pc680 and going to likely mount it exactly like you, behind the passenger seat... or possibly underneath it, if it'll fit. I've heard mixed reviews about the PC680, but figured i'd give it a shot anyways.
Driver's manifold modified. I originally did the passenger side in 2.25" but this is 2.5" with a ball and socket flange. I'm going to pull out the passenger side and re-do it. It'll be a tight fit, but I should be able to get it fitted. may just get a v-band flange for the other side actually. Need to order up bends for the rest of the exhaust and also need to get welding gas, I ran out. going to get these ceramic coated when I get a chance too.
First time in 21 months that the car has moved under its own power.....
washed it and drove it around the block today.
ordered mandrel bends for exhaust the other day. Also ordered MGW shifter because I don't trust the shifter that is in there (saw the current shifter on ebay for $30 shipped... new)
well as you'll see in this post... I decided to tackle the exhaust myself.
Bought a chop saw around 8 tonight....
Exhaust bends came in today and got straight to work.
Started on the front section of the exhaust....
at the y-pipe... need to cut the passenger side pipe down a couple inches and then squeeze a bend in there to get it to the y-pipe.
I'll hopefully have everything up to the y-pipe finished tomorrow and then i'll finish out the back half.
Front section finished.
Just need to pull it back down to finish welding the rear section in place...
The rear section is only tacked in place, so there are definitely leaks but here's a quick vid. Mind you its a bone stock ls1... not that exciting sounding..
bad quality video...
Edited by 280zcar
