Kevin.pk Posted June 2, 2014 Author Share Posted June 2, 2014 Compressor installed. Took a bushing made for a lawnmower idler pulley and cut it down to install smooth idler pulley. Pulley is installed where one of the long f-body alternator bolts are. Ordering up hoses and fittings and hoping to have everything buttoned up sometime next week. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted June 10, 2014 Author Share Posted June 10, 2014 Hoses and fittings came today. Have the drier and Condenser mounted and started to mock up all the hoses. Lines coming off the compressor Condenser and Drier mounted with hoses mostly in place. Had to make a small notch on the driver's side of the core support for the Condenser to fit. Need to make a matching bracket for the other half of the top of the condenser. Running the #8 and #10 lines along the bottom of the condenser. Got a little carried away trying to make the lower bracket look nicer. Hoses are run through the fender horn. Early cars have this area already open, but I guess they blocked it off on '78 cars. I had to cut open this section to pass the hoses through. Quote Link to comment Share on other sites More sharing options...
78zstyle Posted June 10, 2014 Share Posted June 10, 2014 Impressive work as always Kevin. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted June 20, 2014 Author Share Posted June 20, 2014 (edited) A/C is a wonderful thing. Got hoses crimped and system charged. Made a bracket for the Drier. I wasn't happy with the two little straps that Vintage Air provided. Bracket is just some left over 2.5 exhaust split and a couple tabs welded on to tighten it around the Drier. All buttoned up. Trinary Switch wired. Fan relay got moved to the lower condenser bracket.(used to be mounted where the drier is now) System Getting charged Edited June 20, 2014 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted September 18, 2014 Author Share Posted September 18, 2014 (edited) This is really simple and basic install but thought some other folks might like it. Bought a usb charging outlet/panel from amazon: http://www.amazon.com/gp/product/B00IRJH8CE/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 I popped out the small square port in between the fasten seatbelt and defogger lights. The hole did have to be opened up. If you have a pristine center console, this would be a hard pill to swallow, but mine is beaten up so i had no problem opening up the hole some. Wiring is super simply. Just supply switched 12v and ground to the two spade connectors on the back and you are done. The front panel has a fairly obnoxious blue light that is on all the time. I intend on painting over it, but there is a rubbery cover for it when not in use. Installed one in my daily as well. (shows the light on) Edited September 18, 2014 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted January 17, 2015 Author Share Posted January 17, 2015 Upgraded the clutch to a Monster Stage 2 and 18lb flywheel. Didn't really take much in terms of pictures. Clutch drives pretty much like stock. Still breaking in though. Motor pulled and back together Quote Link to comment Share on other sites More sharing options...
nissanthanh Posted January 19, 2015 Share Posted January 19, 2015 Hey 280zcar, do you have a part number for the short feed and return lines you used for your tank? Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted February 27, 2015 Author Share Posted February 27, 2015 (edited) Some new parts came in. As soon as it warms up in Dallas, I'll get started putting it all on. Techno Toy Tuning Bolt in Camber Plates Techno Toy Tuning Coilover Top Plates 300lb/in springs Steering Rack Boots Camber plates will be installed up front. Rear will get done later, but think I need to source some stock strut tubes for the rear. I may end up being too low after removing the stock isolators for the plates (struts are currently sectioned). Edited February 27, 2015 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted March 27, 2015 Author Share Posted March 27, 2015 (edited) Installed a front tow hook. Purchased this: http://www.amazon.com/gp/product/B00DJSRSSM/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 I think the the threads in the the hook are 12x1.75.The part that threads into the black part of the hook was discarded. So I went to to the local hardware store and got a long 12x1.75 bolt and some 1/4 steel plate. Cut the steel plate to size 4"x2.75" and drilled two holes for mounting it to the stock front bumper location. Welded the bolt to the steel plate and done. Finished product before paint: Hook can be oriented in any direction since it is screwed in place. I chose to have it swing left and right because it can fit in the space to the side of my grill. I don't know how much I trust the strength of the $11 piece of red aluminum but it hopefully will handle pulls on to a tow bed should I ever need it. I may search for an all steel ring that will screw on to the same threads. Edited March 27, 2015 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted April 8, 2015 Author Share Posted April 8, 2015 Installed one of the T3 Camber Plates. I made rough cutouts with a drill and hole saw bit. Then followed up with a mini hacksaw and then finally a lot of filing. During cuttting. Mostly completed. Need to do a little more cleaning up and then throw some paint on it. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted May 26, 2015 Author Share Posted May 26, 2015 (edited) Finished out the Camber plate install. Bought a a pair of new-to-me fenders off craigslist and headlight extensions from a member. Looking at paint options now. 255/40/17 Toyo R888 put on the back Edited June 10, 2015 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
78zlt1 Posted May 31, 2015 Share Posted May 31, 2015 Just piecing together the A/C components one by one really. 12"x24" Condenser from ackits.com $61.51 You don't happen to have the part # for the condenser? It looks like the ports are on the same side, Thats what Im looking for. Thanks! Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted June 2, 2015 Author Share Posted June 2, 2015 it was part number CN 20002XC. Quote Link to comment Share on other sites More sharing options...
78zlt1 Posted June 3, 2015 Share Posted June 3, 2015 it was part number CN 20002XC. Awesome, Thanks alot ! Quote Link to comment Share on other sites More sharing options...
ladams17 Posted June 4, 2015 Share Posted June 4, 2015 where did you buy your fenders from? Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted June 10, 2015 Author Share Posted June 10, 2015 where did you buy your fenders from? I realize now that I should have said "new to me" instead of "new" fenders. I picked them up used off craigslist, they just happened to be a similar silver. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted March 28, 2016 Author Share Posted March 28, 2016 (edited) I've been stock piling more parts than I have been installing them. Parts waiting to be installed: Corbeau FX1 pro 5 point harness Speedhut Oil pressure guage Speedhut Water temp gauge New exhaust pipe to get the exhaust tucked a little higher. Parts actually installed: 240z Front bumper Soooo here is a pic with the new bumper installed... Edited July 7, 2017 by Kevin.pk Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted 21 hours ago Author Share Posted 21 hours ago (edited) Well... its been almost a decade... better get restarted... Started messing with a new front turn signal. Cutting up airdam brake ducts and integrating a turn signal from a late 90's integra. I flipped the turn signal to better match the contours at the bottom of the airdam. What else is done or in the works... New interior - dash, center console, door panels, seat, carpet, gauges, sound deadening Vintage air HVAC control panel upgrade Coolant and heater hose upgrades Hydrualic hood hinge setup Silvermine Power steering Apex rear strut bar Subframe connectors Passenger seat - corbeau fx1 pro Vinyl wrapped hood Sanded/polished exterior light lens Exhaust work.... again and still Mfactory lsd T3 front sturt bar T3 harness bar Honda wiper upgrade LED headlights Skillard front lip More posts to come soon. Edited 21 hours ago by Kevin.pk 1 Quote Link to comment Share on other sites More sharing options...
