primer&rust Posted April 16, 2007 Share Posted April 16, 2007 You can use a thermostat from a Chevy V8 if you want 160 degree. A parts guy at Napa Auto told me this and I have been running a Chevy 160 stat in my car for years with no problem. They are a perfect fit and can be bought in stainless steel for a decent price. Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 17, 2007 Share Posted April 17, 2007 The open-loop/closed loop situation is borderline. Like I said, the 160 will not be fully open till 170, and that is near close to remove the cold start (or open loop) situation on most cars. ECU variations, or even resistance in the harness can skew this. On a car with a standalone, you program accordingly. Thermal performance of the coolant system works on heat rejection. I would have to see the car run cooler on a 195 t-stat and run some instrumentation on it to understand what is going on in the supercharged scenario. That just sounds strange to me. On the car with the MAF going to open loop a simple resistor would have solved his problem with the ECU switching to open loop. And disconnecting the MAF Water Jacket (I believe) is screwing with the bypass circuit within the block...making for longer warmups due to no internal water recirculation while the thermostat is closed after initial start. Having an air temperature sensor bad didn't help either... As well as the reflashed EPROM... and O2 Sensor conflict sending the car to open loop regardless of what temperature it's operating... There was FAR more problems on that car than a 160 degree thermostat. Like I stated before, the Nissan ECU's look for just over 170 degrees. In worldwide applications a 'tropical' thermostat is 72C... Quote Link to comment Share on other sites More sharing options...
GeeZ Posted April 17, 2007 Share Posted April 17, 2007 I remember now about the Chevy theromostats. Has anyone checked out the "fail safe theromostat?" I guess when they fail they fail open. I just noticed this on the Autozone site. Wonder if they work. Quote Link to comment Share on other sites More sharing options...
