Lurch2461 Posted April 15, 2007 Share Posted April 15, 2007 Hi All, Can anyone tell me if the Nismo adjustable cam pulley is available in USA/ Thank you, Dennis Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 15, 2007 Share Posted April 15, 2007 I would talk you the guys at Stewart Wilkins Motorsport http://www.swmotorsport.com they can supply adjustable cam sprockets these are not Nismo ones but better I feel. The Nismo units have extra mounting holes so you can adjust the cam timing in +-2 degree's at a time. The ones SWM sells have more adjustment and if I recall a cheaper too. Attached is a pic of the two type of adjustable cams side by side. The left is like the one SWM sells the right is like the Nismo unit. Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 15, 2007 Share Posted April 15, 2007 There are two different units available on E-Bay right now. The NISMO unit for $96, and a Kameari for $200+. Both in the USA. Quote Link to comment Share on other sites More sharing options...
2003z Posted April 15, 2007 Share Posted April 15, 2007 and the Nismo unit is available through dealerships. I was going to use the .6mm nismo headgasket, to which Nissan Motorsports said I needed that unit with, and both were available 2 months ago. I wound up buying a 1mm headgasket from a member here instead. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted April 16, 2007 Share Posted April 16, 2007 I just scooped up that Kameari adj. cam sprocket off ebay after I made the seller an offer. Thanks for posting that Tony. Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 17, 2007 Share Posted April 17, 2007 Oh, I was being facetious... Damn! I think JeffP had a mainline to get those cheaper. Ah well, if you got it under $200 you did O.K. Quote Link to comment Share on other sites More sharing options...
