GrayZee Posted April 15, 2007 Share Posted April 15, 2007 I've been working at a way to connect the stock turbo oil feed to my Hy35 without having to tap the center section. This method certainly works but it makes me nervous that I won't be able to remove all the shavings and end up damaging the turbo. I went to my local haudraulics shop looking for some sort of adapter. They usually always have a answer to your problem. This time though, no luck, they spent 20 min just looking for something... anything that will even thread in properly. They had no answers for me, I decided to find out exactly what this elusive thread was. I looked online for info and I found many statements claiming that the Holset threads were M10x1.5 These turned out to be incorrect as a M10 bolt was way too small, and a M12 was way too big. 11 I thought? Naw... couldn't be.. I tried 7/16, close but wrong thread pitch. I finally decided to get my hands on a thread pitch gauge, turns out they were a 1.5 pitch.. definatly metric! I called around to try and find any one that carried a M11 anything... bolt nut, whatever... Nothing.. I called a specialty tool shop and asked if they could get me a M11x1.5 tap or die. They said it would take a week but they could get me one.. I ordered a die for $13 I was hoping to be able to ram the die a M12 bolt but there was still way too much meat there. I found someone that would machine it down to 11mm for me then I tapped it. Perfect fit!! Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted April 15, 2007 Share Posted April 15, 2007 I'm using a HE-351 and Big-phil is using a holset of some kind a HE-351, HY-9 or HY-35w...12x1.5 worked for us... just drilled through the center to make it a banjo bolt. Quote Link to comment Share on other sites More sharing options...
NCchris Posted April 15, 2007 Share Posted April 15, 2007 If it's M12x1.5 forsure: http://www.pegasusautoracing.com/productdetails.asp?RecId=5055 FWIW, these guys got lots'a good odd stuff. chris Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 15, 2007 Share Posted April 15, 2007 Yes I think I used a 12x1.5 bolt, drilled the center out, then drilled a hole cross ways and made my own banjo bolt. stock is on the left, home made on the right. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 16, 2007 Share Posted April 16, 2007 weird.. I used the stock oil lines with my Holset! stock drain and stock feed! Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted April 16, 2007 Share Posted April 16, 2007 I also used everything stock.....but the bolt... did the same thing as Phil. Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted April 16, 2007 Share Posted April 16, 2007 i just converted over to a -4an and used a stainless braid -4 line. doesn't fit as tight as the stocker, but it's nice to have all that flex w/ out worry of cracking a hardline. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 18, 2007 Author Share Posted April 18, 2007 Well now I am really confused... Obviously there a MANY different types of oil line threads on Holset turbochargers. The stock Nissan bolt is M12x1.5 and the one that Big Phil has according to the pic is even larger than that. I had hoped to leave some info to help out anybody that does this swap but nevermind, every swap is going to turn out different.... So you guys are on your own... Ha ha ha.... Quote Link to comment Share on other sites More sharing options...
nish Posted April 18, 2007 Share Posted April 18, 2007 FWIW: Holset HY35 (2003 anyways) oil feed fitting = 12mm * 1.5 o-ring I used an Earl's -4ANto12mm adapter from Summit PN: EAR-9919BFGERL $10.00 It runs in easily by hand. Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted April 18, 2007 Share Posted April 18, 2007 Grayzee, measure that stock bolt again and I think you will find it's not 12mm. Quote Link to comment Share on other sites More sharing options...
NCchris Posted April 19, 2007 Share Posted April 19, 2007 nish said: FWIW: Holset HY35 (2003 anyways) oil feed fitting = 12mm * 1.5 o-ring Same as HE-351 (newer HY-35) HTH chris Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 19, 2007 Share Posted April 19, 2007 my holset is a 2006, and yes the bolt was bigger than stock. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 23, 2007 Author Share Posted April 23, 2007 nish said: FWIW: Holset HY35 (2003 anyways) oil feed fitting = 12mm * 1.5 o-ring I used an Earl's -4ANto12mm adapter from Summit PN: EAR-9919BFGERL $10.00 It runs in easily by hand. Mine was a 2003 also... Quote Link to comment Share on other sites More sharing options...
niner11 Posted November 23, 2008 Share Posted November 23, 2008 Slow Old Car, I was wondering how long of a flexible oil line you used for your feed line. Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted November 25, 2008 Share Posted November 25, 2008 niner11 said: Slow Old Car, I was wondering how long of a flexible oil line you used for your feed line. 4' could be done with less, but it leaves room for keeping good distance from hot parts + jacketing for heat resistance Quote Link to comment Share on other sites More sharing options...
jacob80 Posted June 22, 2011 Share Posted June 22, 2011 Bringing this topic back up... ...I'm going to route a 4' run of braided stainless steel line straight to the HY35 off the stock oil distibution block oil feel port on the passenger side. What are the thread on the port? I would like to convert it to an to have a nice AN oil feel line with female connectors on both ends. Also, is it safe to have a straight run of line, or do I need some kind of restictor? How about a filter? Thanks. Quote Link to comment Share on other sites More sharing options...
