nbesheer Posted May 15, 2007 Share Posted May 15, 2007 Okay I was originaly planing on getting a SCCA roll Bar from MSA. The only reason I didn't want a cage is because I heard it can be just as deadly if you hit your head on the steel but There is padding for the bars right that would make it about as hard as hitting the dash bord I would assume. So is it possible to make a cage in a S130 that still allows for the t-tops to function and also is suitable for a DD. And can be built with the car intact. ie no cutting roof off or what ever. for you guys posting "use the search" ill post that for oyu. "Search button is over there :points:" "next time try searching" "if you use that thing called searching you might get answers" Anyways I've searched and I came up with this thread http://forums.hybridz.org/showthread.php?t=119381&highlight=t-tops+roll+cage But that is for a 300ZX meanwhile I have a 83 280ZX and was hoping it would work for me as well. (I searched for roll cage t tops/t-tops roll cage/roll cage) and didn't get anything significant which is why I'm posting. Quote Link to comment Share on other sites More sharing options...
johnc Posted May 15, 2007 Share Posted May 15, 2007 So is it possible to make a cage in a S130 that still allows for the t-tops to function and also is suitable for a DD. And can be built with the car intact. ie no cutting roof off or w/e What's "w/e"? Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted May 15, 2007 Share Posted May 15, 2007 What's "w/e"? I'm guessing 'whatever' John Quote Link to comment Share on other sites More sharing options...
nbesheer Posted May 15, 2007 Author Share Posted May 15, 2007 I'm sorry yes w/e is what ever. I'm trying my best not to do abbreviations Quote Link to comment Share on other sites More sharing options...
johnc Posted May 15, 2007 Share Posted May 15, 2007 Yes, a roll cage can be made meeting your requirements. Instead of cutting the roof off, holes can be punched in the floor allowing the main and front hoops to be dropped for welding. These holes will be covered by the mounting plates and a small plate welded underneath the car for reinforcement. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted May 15, 2007 Author Share Posted May 15, 2007 And also will padding on the bars be sufficient protection if you hit your head on them with no helmet ? Quote Link to comment Share on other sites More sharing options...
johnc Posted May 15, 2007 Share Posted May 15, 2007 No. Imagine me hitting you in the head with a baseball bat that's wrapped with a bit of foam. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted May 15, 2007 Author Share Posted May 15, 2007 Well then roll bar it is Thanks again. Quote Link to comment Share on other sites More sharing options...
LLave Posted May 16, 2007 Share Posted May 16, 2007 No. Imagine me hitting you in the head with a baseball bat that's wrapped with a bit of foam. :mrgreen:That is a great way to sum it up and get right to the point. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted May 16, 2007 Author Share Posted May 16, 2007 With out having actually seen a roll bar like the one sold as MSA, they sit behind the seat in non head hitting areas right ? Quote Link to comment Share on other sites More sharing options...
johnc Posted May 16, 2007 Share Posted May 16, 2007 Yes. Quote Link to comment Share on other sites More sharing options...
Guest Gr8White Posted May 16, 2007 Share Posted May 16, 2007 If you hit your head on the roll bar then you aren't buckled in securely anyway I wouldn't think. I know it's a pain, but I always wear my harness in my street car. Buckling up is the law anyway (in Texas anyway), you might as well do it right.... Quote Link to comment Share on other sites More sharing options...
nbesheer Posted May 16, 2007 Author Share Posted May 16, 2007 I do plan on wearing it right all the time Quote Link to comment Share on other sites More sharing options...
