uccreepanddrums Posted May 18, 2007 Share Posted May 18, 2007 i am looking at the apexi neo.....does anyone run this or know for sure that it will be compatible with the stock ecu?? thanks Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 19, 2007 Author Share Posted May 19, 2007 bump Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted May 19, 2007 Share Posted May 19, 2007 Just rip it and put in MegaSquirt... Quote Link to comment Share on other sites More sharing options...
nismopick Posted May 19, 2007 Share Posted May 19, 2007 You can find anything on google... http://www.apexi-usa.com/product_electronics_detail.asp?ID=260 Most 0-5V MAP/AFM cars A quick google search will yield a lot of info about it. Apparently it's got quite a bit of mixed reviews. Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 21, 2007 Author Share Posted May 21, 2007 ok thanks for the help guys Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 21, 2007 Author Share Posted May 21, 2007 are the 280zxs maf, map, or afm(dont know what this is, probably same as maf).....if they are maf or map are they 0-5v? im gonna try to contact apexi but i just need a simple answer for right now Quote Link to comment Share on other sites More sharing options...
LineC Posted May 21, 2007 Share Posted May 21, 2007 Stock form is AFM which is horrible. Basically a large door has to open whenever air has to get to the engine. Do some research and you will find that the boneyard electronics on the 280z and zx'z is inferior and cheaply replaced. Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 21, 2007 Author Share Posted May 21, 2007 ok that is what i needed to know thanks.....im just getting the project going and about to go off to college, just brainstorming right now still need to put my springs and struts on Quote Link to comment Share on other sites More sharing options...
nismopick Posted May 21, 2007 Share Posted May 21, 2007 are the 280zxs maf, map, or afm(dont know what this is, probably same as maf).....if they are maf or map are they 0-5v? im gonna try to contact apexi but i just need a simple answer for right now MAF = Mass Air Flow sensor (aka "hot wire maf). It measures air flow by how much a heated wire is cooled. MAP = Manifold Absolute Pressure sensor (measures the pressure / vac of the manifold). AFM = Air Flow Meter (like LineC said, it uses a flap door connected to a potentiometer to measure air flow). Some SAFC's will work on AFM's, but since most cars these days use a MAF, most SAFC's are programmed to work w/ a MAF. Quote Link to comment Share on other sites More sharing options...
LineC Posted May 22, 2007 Share Posted May 22, 2007 If you do decide to go Megasquirt, the Bowling and Grippo company is local to me and maybe you if your from the Hampton Roads area. Also DIY autotune has everything you need and has a great reputation. I suggest reading this before you spend anymore money, great reading and this will get you to 350hp and beyond on proven/tested experience. http://forums.hybridz.org/showthread.php?t=115904 Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 22, 2007 Author Share Posted May 22, 2007 yeah i live in portsmouth...where do you live? i will give that a look Quote Link to comment Share on other sites More sharing options...
LineC Posted May 23, 2007 Share Posted May 23, 2007 I am in Hampton. The guy I dealt with is a eletrical engineer @ Jefferson Labs in Newport News. He just builds them though and really doesn't mess with the tuning aspect. Quote Link to comment Share on other sites More sharing options...
uccreepanddrums Posted May 24, 2007 Author Share Posted May 24, 2007 good deal maybe i can contact you to go to jenros sometime Quote Link to comment Share on other sites More sharing options...
