gjc5500 Posted May 25, 2007 Share Posted May 25, 2007 The whole car shakes under acceleration. its not really noticeable in 1-3 but in 4th the whole car shakes VERY severly. even crusing in 4th is very shaky. could this be bad ujoints, loose differential, or bad differential mounts? Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted May 25, 2007 Share Posted May 25, 2007 even alignment, suspension bushings, wheel imbalance.... Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted May 25, 2007 Author Share Posted May 25, 2007 alignment right, bushings still in OK condition, wheels balanced. if i accelerate through 60 in 3rd, no shake, same acceleration in 4th, bad shake Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 25, 2007 Share Posted May 25, 2007 Id check the driveshaft and u joints. When my car was on the road we got the driveshaft worked on and it really helped. (the shake) Quote Link to comment Share on other sites More sharing options...
piston Posted May 25, 2007 Share Posted May 25, 2007 mine shakes and stops frequently. im not sure whats wrong with it, it vibrates at acceleration but stops at crusing. then sometimes it just doesnt vibrate at all. all three of whats listed is probablymy problems. im not sure why it does it at low speeds sometimes and stops. i have old stub axles and joints. not too confident on driveshaft. and for sure old bushings with unbalanced wheels. Quote Link to comment Share on other sites More sharing options...
v8dats Posted May 25, 2007 Share Posted May 25, 2007 shafts and joints. more than one on z's. Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted May 25, 2007 Author Share Posted May 25, 2007 Tonight or early toamrow im gonna get the car on a rack, change the ujoints and tighten the mounts on the tranny, motor, and differential Quote Link to comment Share on other sites More sharing options...
bjhines Posted May 26, 2007 Share Posted May 26, 2007 If the shake is typical of wheel or tire issues... then have the tires "Road Force" tested to see if they are the problem. Driveline vibrations tend to be a hum as much as a shake.. tire issues are usually lower frequency... Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted May 26, 2007 Author Share Posted May 26, 2007 BINGO! dropped the drive line. the rear ujoint had 2 of the clips fall out. the joint was moving around in the yoke. replaced the ujoint, no vibration up to 110mph. Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted May 26, 2007 Share Posted May 26, 2007 good think it didnt let loose! Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted May 26, 2007 Author Share Posted May 26, 2007 yea, the 4 cups were still on it, 1 cup slid off of the center part but was still there. runs like a champ again, well a champ in the specail honda olypics. Quote Link to comment Share on other sites More sharing options...
