Cody 82 ZXT Posted June 19, 2002 Share Posted June 19, 2002 I'm looking to swap the rear end in my ZX this weekend and looking for any advise anyone may have. I think I'm going to just install a open rear of the desired gear ratio ( there real cheap here) then put in a Phantom Grip when the the money is there for that type of item. Ever since I installed the 17's the car is a little slower so I'm going to step up in gears to get back to the orginal gearing. thanks Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 19, 2002 Share Posted June 19, 2002 Sound like you've already got it figured. I assume you are going 3.90 since you should have 3.7s? I've decided I'm going to hold out until Reider Racing finally gets the LSD units from Japan. I wish I bought one 3 years ago when they were only $425...$550 or so now. They claim the end of June as of last week but they said end of May in April. I've decided to go with the 82-83 3.90 and 12mm ring gear to make adding the LSD easier. I'll check backlash of the open carrier/gearset and shim it to equal that with the LSD. Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted June 19, 2002 Share Posted June 19, 2002 Mike check me as I may be wrong but I think that the only R200s that came with 12mm bolts were the ones that came in 87-89 Z's. Mine is a 83 and it has 10mm ring gear bolts. Don Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted June 19, 2002 Share Posted June 19, 2002 My diff is a 3.90. It has yellow junkyard pen on it that says '82 280ZX'. Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 20, 2002 Share Posted June 20, 2002 Hmmm. Need to get some diffs and check 'em out. When I first started researching the LSD thing about 5 years ago, the one Reider had said would fit 82 and up rears. I THOUGHT I was sure about the ring gear bolt thing, but I guess more research is in order. Worse case scenario, I get the diff and I'll have some custom bolt sleeves built. Quote Link to comment Share on other sites More sharing options...
