stony Posted June 23, 2007 Share Posted June 23, 2007 Hey arnt all 4 bars in a 4 link setup supposed to have rt hand threads at one end and left hand thread at the other end?????? Quote Link to comment Share on other sites More sharing options...
johnc Posted June 23, 2007 Share Posted June 23, 2007 Not that I know of. Why would you need LH threads on a suspension arm mount? Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted June 23, 2007 Share Posted June 23, 2007 If you want to adjust the length of the bar without taking out the bolt in the eye of the spherical joint then, yes... One end needs to be RH and the other LH. Quote Link to comment Share on other sites More sharing options...
stony Posted June 23, 2007 Author Share Posted June 23, 2007 Thats what i thought. Quote Link to comment Share on other sites More sharing options...
johnc Posted June 23, 2007 Share Posted June 23, 2007 Doh! For some reason I was picturing a stamped steel arm 4 link setup like what comes OEM on a Fox body Mustang or a G body GM car. Never mind. Quote Link to comment Share on other sites More sharing options...
stony Posted June 23, 2007 Author Share Posted June 23, 2007 Ok i have figured it out!!! one bar is threaded wrong!!! 3 bars get shorter or longer when turned in a certain direction one bar just stays the same length until either one end falls out of the other shanks out on the bar!!!! So i guess i need one bar made Quote Link to comment Share on other sites More sharing options...
76s30 Posted June 25, 2007 Share Posted June 25, 2007 Just thought I should clarify a 4 bar is not adjustable. a 4 link is. Quote Link to comment Share on other sites More sharing options...
