bubbleguinea Posted June 24, 2007 Share Posted June 24, 2007 once agian, ive lost my map on my car dont ask me how... can someone post a map NA or Turbo...just something around what it should be...i can tune it from there... thanks! Quote Link to comment Share on other sites More sharing options...
spork Posted June 25, 2007 Share Posted June 25, 2007 You know, you really should write those down from time to time... Now, I know you said not to ask...but how can you loose your maps? I've never seen that happen... By the way, I'd post my maps, but they in no way would do you any good what so ever... Quote Link to comment Share on other sites More sharing options...
Supra510 Posted June 25, 2007 Share Posted June 25, 2007 My SDS for a turbo has the RPM map set a 63 for basically every RPM from idle to redline. The MAP sensor map on my motor is set at around 30 for the vacuum around idle (20, 19,18) the goes up about 4 per vacuum point until I get into boost then I go up 7 per lb of boost. Should be enough to get you going. I have 550cc injectors on a 3.0 motor so you'll likely need to lean it out. Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 8, 2007 Share Posted July 8, 2007 Can't you download the data for storage to an off-ECU device? I thought SDS had that ability. If it's all resident in the ECU, then you must manually write down everything? Man, that's a drag! Quote Link to comment Share on other sites More sharing options...
