Need advice on metal to make a harness bar...
No. Well, the sheet metal maybe. DOM tubing is not terribly expensive, but you'll have to find a supplier. Check your yellow pages for steel suppliers. If you can't find one there are online stores that will ship you a piece, and you don't have to buy a 20' stick either. http://www.onlinemetals.com is one that I've used because they happen to be just around the corner, but they'll send stuff to you in vegas.
If you're installing a harness bar you're either racing or looking for attention from the police. Assuming you're racing, I can tell you that there aren't too many sanctioning bodies that will allow less than DOM these days. DOM or chromoly are what SCCA specifies.
Pop is technically correct that a larger tube larger diameter ERW pipe would work, just not a very good choice in my opinion.
