Fun Night at the strip, won 150 bucks!
Booztd 3
Well I got my ECU back from AEM at about 3:30PM on friday, fouled my plugs, and drained my batter by about 4PM.
I finally figured out that AEM had completely wiped my ECU, and after frantic searching, could not find my backup calibrations :( I had the car running off the base-map and the modifications needed for 1000cc injectors by around 4:30 or so, and driving shortly after.
I went out and threw on what I 'figured' to be a safe tune going off of memory from when I was last on the dyno, and it seemed like it was making decent power and the logs were showing decent figures.
I ended up getting lucky when I got to the drag strip and I actually found the damn calibration file! I turned the boost up to 16-17psi and made some passes. The track prep was ♥♥♥♥ because it was 'street-car' night, however I was happy with my trap speed. I also hadnt played with the 2-step at all so it was taking some getting used to that......
I could only muster a handful of 12.0's because the car was simply not getting out of the hole, however I had the MPH for low 11's. The best of the night was 124..... Here are some vids
http://www.booztd3.com/Videos/Midnight_Mayhemt_In_Car_01.wmv
http://www.booztd3.com/Videos/Midnight_Mayhem_6_29_2007_03.MPG
http://www.booztd3.com/Videos/Midnight_Mayhem_6_29_2007_05.MPG
http://www.booztd3.com/Videos/Midnight_Mayhem_6_29_2007_08.MPG
I ended up winning a trophy and 150 bucks for being the import with the fastest trap speed, and the biggest award of all was that I was able to drive the car the 90 miles home w/out any issues all while getting 30+mpg!!!
LaterZ
ALOT
A buddy with a TH400 setup in a Z dropped his 60ft times over 2 tenths (and he was already doing 1.5 60 foots) and he's not falling out of boost near as bad as the 5spd was.....
I'd say I could gain a second at least just by going to the th400
  • Administrators
124MPH with a 3800lb Z32 means you are making some serious HP. Nice! I like the race against the late model Camaro. You tree'd him bad.
Your camcorder operator seems to be a big fan. :)
3800lbs? WOW!
I thought my '93 N/A car was heavy, less than 1/8th tank, me and my 100 lb daughter, 3600 lbs even on the scales. oink.gif
Do I enderstand correctly that you are running an RB engie in your Z-32?
3800lbs? WOW!
I guess I exaggerated the weight because I was so impressed. I have corrected my post. :oops:
  • Administrators
Very nice. Clean, uncluttered, well executed power train conversion, 124 MPH trap = incredible street performance. A sports car that any discerning sports scar enthusiast could truly appreciate on many levels.
Nice car.
