**HELP!** AJCdavid stuck in symrna, GA
check http://www.zcar.com for the thread...i called his cell phone...
car randomly died on the interstate... 1976 280Z 2+2
he DOES have fuel pressure via guage
he DOES have spark
im thinking power to the injectors? they are brand new
what about AFM fuel cutout? could that go bad?
anyone around here want to help me out...give my call a call... 678-860-4015
he will be in symrna in about an hour.
just got a call from him, he is safely in symrna...
the coil has nothing to do with it...nor due fusible links....
he is getting perfect spark, and perfect fuel pressure....good airway passages...
the ONLY thing this leads to is fuel delivery via the injectors...ie the injectors are not firing...
what is between the ECU and the fuel injectors????
could the ECU have instanly gone bad??? what about the ECU/fuel pump realy? that wouldnt work cause his fuel pump has power...
just thinking out loud here...
he got the car towed to e. raddatz motorsports...
as eddie was doing a check on the fusible links, i poped the distributor cap off...
the rotor just fell off the dizzy, and i looked at it and noticed something was different...the metal piece was missing!!! it was laying deep down in the dizzy, which wobbled back in forth about 1/4inch. the bushings in the thing went out!!!
i guess it wasnt getting spark afterall!!!
we slapped a new dizzy on, new cap and rotor, and the car roared to life!
ariel is a great guy!
hope you got home OK!
