couple quick vids of the rb25 in the z
scottyMIz
these runs were in third gear i need to hook the vvt and see if she spools up better
sorry for droppin the cam :)
does run nice and in both the clutch started slipping at about 15psi and at about 5500 rpm. you can hear me in the second one letting off and getting back on it in the end
yea it is floored but it is not slow, the turbo i have is a t4e with a .70a/r on the compressor has the stock .63a/r on the turbine but it's machined out to handle a full t4 wheel. Also my rb trans with the 3.54 rear gear is equal to 6th gear in a 350z. 2200rpm is 60mph i wish it spooled quicker but the turbo's sweet spot is between 10 and 25psi so i'm just getting into the power when it slips
no boost leak, i checked u have to realize that this is not a t3 turbine anymore so spooling the turbo will be slower with a 2.5l vs a 2.8 also i can hit over 100mph in third tis thing is geared very low, like i said the vvt isn't hooked up yet so it might help a bit.
  • 4 weeks later...
