Can I convert ls1 Engine auto trans to t56
Can I convert ls1 Engine with auto trans to t56? Will there be any problems with the ecu and harness after the change. Will the car run with that setup? Thanks
The LS1 I bought came with a 4L60E auto trans. I bought a T-56 and installed it in place of the auto. The car ran fine with the computer as-is from the auto. I drove it that way for several months before I finally had it reprogrammed for the 6 speed. It did throw a few codes and the signal for the speedo was wrong but other then that, it still worked fine.
like qwik240z said, you can prolly convert easily from auto to manual because with MT the driver controls all the shifting. Converting MT to auto might pose a problem as the software and sensor that control automatic shifting might not exist in the MT car. I know converting from M6 to A4 is not what you want, but I am just saying.
I am still torn between A4 and M6...qwik240z, do you still have the auto trans?
  • 5 months later...
You don't need to rewire the harness. The PCM connectors should have all the wires to support auto trans or the T56. For the auto trans the PCM controls the TCC (Torque converter clutch) and it needs the input signal from the brake. For the T56 I forgot what the PCM controls but it needs the input signal from the clutch. If you need wiring info let me know. I will have to go back to do some more reading on the T56. GL
Vinh
PS. I can rewire the harness also.
Vinh
That's the kind of post I love to see in that you get an answer and an offer to help all at the same time.... Only on HybridZ:smile::-):smile:.
LARRY
Larry,
lol..
Here is the PCM wiring pinouts that I save only the wires that have something to do with both transmissions. Most of these are for the auto trans. I remember there are 3 connectors on the T56 and they are for: Reverse lock out selenoid, Skip shift selenoid and the last one is the reverse light switch. The reverse light switch wires do not go to the PCM. So you just need to remove all the wires for the auto trans and hook up 4 wires from the T56 to the PCM for the reverse lock out selenoid and the skip shift selenoid. Important: Make sure you get the connectors to all the sensors/switches on the T56. GL
Vinh
Document ID# 1021267
2004 Pontiac GTO
Powertrain Control Module (PCM) Connector End Views
Table 1: PCM Connector C1
Table 2: PCM Connector C2
PCM Connector C1
Connector Part Information
PCM Connector C1 92231110
80-Way Micro-Pack 100W Series Sealed (BU)
Pin
Wire Color
Circuit No.
Function
17
YE
1225
Transmission Fluid Pressure Switch Signal B
18
GY
1226
Transmission Fluid Pressure Switch Signal C
32
BU/WH
771
Transmission Range Switch Signal A
33
BN
86
Cruise Control Release Signal
34
WH
776
Transmission Range Switch Signal P
53
BK/WH
2762
Low Reference - TFT Sensor
72
YE/RD
772
Transmission Range Switch Signal B
79
GN/WH or GY
898 or 587
Shift Solenoid Valve 3 High Control - Skip/Shift Solenoid Control
PCM Connector C2
PCM Connector C2 92231110
80-Way Micro-Pack 100W Series Sealed (GN)
Pin
Wire Color
Circuit No.
Function
2
BN
418
TCC PWM Solenoid Valve Control
6
RD
1228
PC Solenoid Valve High Control Sol.A
8
GY/BU
1229
PC Solenoid Valve Low Control Sol.A
20
TN
1231
AT ISS Low Signal
21
BU/WH
1230
AT ISS High Signal
42
GY/RD
422
TCC Solenoid Valve Control
44
YE
1652
Reverse Lock Out Solenoid Control
47
YE/BK
1223
2-3 Shift Solenoid Valve Control
48
L-GN
1222
1-2 Shift Solenoid Valve Control
51
YE/BK
1227
TFT Sensor Signal
62
GY
773
Transmission Range Switch Signal C
63
BN/YE
1224
Transmission Fluid Pressure Switch Signal A
2004 Pontiac GTO
