AC belt too short
dapiper
Stock size too short, next size too long. All '77 OEM. Why? Maybe boneyard gave me '79 AC and compressor mtg brkt different? Hate that belt squeal during start-up.
Does AC compressor have swing adj like alt?
Stock '77 AC has an adjustable idler pulley and compressor bolts solid to a steel bracket. The 280ZX compressor mount is different (aluminum). The ZX AC pulleys all use a thinner belt than the 280Z to make room for the extra power steering belt. Most dealer installed compressors I've seen use a swing adjust bracket for the compressor.
Do you have a Hitachi SWP167 compressor? If not, it is most likely from a dealer installed AC system and you'll need a different bracket or a different compressor.
...The 280ZX compressor mount is different (aluminum). The ZX AC pulleys all use a thinner belt than the 280Z to make room for the extra power steering belt..
Some clarification: The early ZX’s AC compressor used the wide belt like on the 1974-78 Z’s. The power steering pulley was a stamped steel piece that was bolted to the front of the harmonic balancer. They also used the same cast iron mount as the early Z cars.
The later ZX’s changed to the thinner belt. According to a Nissan TSB it was done to reduce belt drag.
The compressor mount was changed to aluminum when the mount was re-designed for the ZX turbo engine. A mounting boss was added for the crankshaft timing pickup. Nissan then just used the aluminum mount on all the NA ZX’s.
