eightytwoturbo Posted August 17, 2007 Share Posted August 17, 2007 Well I am starting to get fuel issues again with my car, I can pinch off the line going to my FPR and it revs great but when I let go and let it run normal it bogs and wont rev past 2k, I just bought a brand new FPR so I know this isnt the problem, is my motor saying "TOO MUCH FUEL?" But I just thought the regulator was just for the return line eh? I know it is not a vacuum leak because sometimes it would run perfect then back to crap. And my vacuum is reading 25. Fuel pressure seems normal. I use to have this problem but then it would go away after driving it for about 10-15 minutes but now I think its here to stay and has been like this for 4 days. Here are some of the things ive tried: plugs plug wires rotor cap and button new injector plugs fuel rail cylinder head temp sensor timing brand new TPS Mass air flow sensor The car is stock 280ZXT besides intake/exhaust. Any Idea's what could be causing this? Im pulling my hair out!! Quote Link to comment Share on other sites More sharing options...
eightytwoturbo Posted August 17, 2007 Author Share Posted August 17, 2007 BUMPPP! I wanted to start my fmic project tommorow but this is happening now! Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 17, 2007 Share Posted August 17, 2007 What is your actual fuel pressure? Short of that, there is no other place to start from the information in the post. Clean connections on all EFI related points, including ECU plugs and pins. Clamping the return line makes fuel pressure go up, meaning lean. Normally everything makes these run rich... "Bogs" is a pretty non-descriptive adjective, do you mean it's popping and backfiring and just not going over 2K? If so, I'd look to dirty electrical connections on injectors and the ECU failing all else. Quote Link to comment Share on other sites More sharing options...
eightytwoturbo Posted August 17, 2007 Author Share Posted August 17, 2007 Ive cleaned everything atleast 3x dealing with the EFI including the ecu. Bogs as in holding the gas down and the rpms go up then down, intake pop and backfire yes, more of sputter/spit sound. I have taken it to Nissan and they said my fuel pressure was correct...when this problem was going on. Guess I have to buy a gauge and test but dont see the point if nissan said all was good. What else would you like to know? I need help asap... confused =/ Quote Link to comment Share on other sites More sharing options...
TravRMK Posted August 17, 2007 Share Posted August 17, 2007 Pop, and backfire = lean. Quote Link to comment Share on other sites More sharing options...
eightytwoturbo Posted August 18, 2007 Author Share Posted August 18, 2007 so possible ecu, what else? faulty injector? Quote Link to comment Share on other sites More sharing options...
