Adapting 2nd generation RX7 control arms
I'm interested in adapting a set of 2nd Generation RX7 FC front lower control arms to my 280z.
Attached are some pictures of a 240z owned by marcg:
http://www.cardomain.com/ride/563982/2
He went ahead and built a subframe to mount the control arms to. I would simply like to make mounting points that are permanent. What are peoples thoughts on doing this?
2nd generation RX7 control arm, Mitsubishi ball joint, stock 240Z strut and steering knuckle, 84 Z31 AE spindle.
Regards,
Justin
The reason I had to resort to such a control arm design is due to the fact that the stock VH45DE exhaust manifolds wanted to be in the same location as the tension rod box. By removing this I now had more room to later put in a proper tuned header system as well.
The draw back is that unlike the adjustable tension rods, making suspension adjustments for the castor is more difficult.
It was allot of work but I had little other options.
The Mitsu ball joint has the same taper as the stock Z steering knuckle. Due to it's design it was easy to machine an arm to adapt it to the RX7 control arm. The front pivot mounted into the stock subframe without too much trouble.
Regards,
Justin
Once you have gone to that amount of trouble you may as well use the mazda strut as well. That way you get nice light weight hubs and vented brakes with 4 pot calipers as well. They are also front steer so it should work out nicely.
Douglas
Douglas
But then you have to check the strut tube length as well as the hub to steering rack mating up.
From what I've read, the amount of caster needed is highly dependent on which wheel/tire combo you are running. I will likely just settle for a middle of the road caster angle since I wont be able to easily adjust it.
Justin
That's why I kept as much Z stuff as I could. I had done several Z car suspensions and thus knew what I had to do to get them lowered and working right. I had enough new things to design and make that working with Z parts would be a no brainer.
As far as castor goes, be careful not to get too much castor with wide wheels.
Douglas
The motor he is using may create a problem as far as clearing the front Xmember and steering rack but I agree with you in principal. As a general rule, later model suspensions have better geometry and heaps of aftermarket stuff available too. Another way around his exhaust clearance problem would be to use a strut suspension which has front located tension rods eg S130, S13/14/15.
Still its a nice job he's done :)
