drifterZ_74 Posted September 5, 2007 Share Posted September 5, 2007 so after weeks of searching old posts still no answer!....i recently swapped an L28et into my 74 260z...car drove fine for a couple of days...but all of a sudden the car started to die out after a couple of minutes of being on....heres the problem: if i start the car it turns on and idles fine...once it warms up the car all of a sudden begins to die out....so i rev and rev and rev until it just dies out..leaving a cloud of smoke from the exhaust...if i try to restart the car it wont turn on but the fuel pump does!...once i have waited a few minutes the car starts up like if nothing happened!...i really dont know what it is!...any advice would be helpful!...thanks! Quote Link to comment Share on other sites More sharing options...
naviathan Posted September 5, 2007 Share Posted September 5, 2007 Sounds like you're either too rich or too lean. Pull the plugs and check the color. If you need help reading them post pics. We'll need more information to help you out. Quote Link to comment Share on other sites More sharing options...
DuoWing Posted September 5, 2007 Share Posted September 5, 2007 I wonder if your fuel pump is on it's way out. You said that the car ran fine at first? Just because the fuel pump is coming on doesn't mean it's good. I've heard that usually the fuel pump has more problems when warm, so it could be that after sitting for a couple of minutes or so it cools down a little. I'd say get a vacuum gauge, and a fuel pressure gauge. Check your vacuum to see if you have leaks that'll tell you something as far as if your pulling air in or not. Then keep the car idling with the fuel pressure gauge hooked up. Watch and see if pressure starts to drop after the car has warmed up. Quote Link to comment Share on other sites More sharing options...
drifterZ_74 Posted September 5, 2007 Author Share Posted September 5, 2007 ill check the plugs and post some pics....but i bought the fuel pump brand new..its an msd...could it be a problem?? Quote Link to comment Share on other sites More sharing options...
drifterZ_74 Posted September 7, 2007 Author Share Posted September 7, 2007 so i removed the spark plugs to check them and they were completely black!...what does that mean??? Quote Link to comment Share on other sites More sharing options...
JSM Posted September 12, 2007 Share Posted September 12, 2007 Black means to much gas. Switch the plugs out and see if it runs good again. If it does then start looking at why it is running so rich. You've finally fowled the plugs thus the poor performance. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 13, 2007 Share Posted September 13, 2007 so i removed the spark plugs to check them and they were completely black!...what does that mean??? Get it fixed before you drive it. By your comment that you installed a different fuel pump on the car, I would look at that or another problem that could be diagnosed like a fuel pump. Quote Link to comment Share on other sites More sharing options...
drifterZ_74 Posted September 14, 2007 Author Share Posted September 14, 2007 thanks for the help..i will change the plugs and check the pump... Quote Link to comment Share on other sites More sharing options...
chrism Posted September 15, 2007 Share Posted September 15, 2007 If none of that works, check the fuel regulator to see if it is creating too much fuel pressure to build in the fuel rail. Quote Link to comment Share on other sites More sharing options...
