palauoriginal Posted September 9, 2007 Share Posted September 9, 2007 Was wondering if the Camber kits were worth the money since they only offer up to .75 degrees in camber. would get coilover+camber plates but my budget is low... heres a pic im wondering because im thinking of getting an alignment soon. here's the link: http://cgi.ebay.com/ebaymotors/SPC-FRONT-CAMBER-KIT-DATSUN-240Z-260Z-280Z-810_W0QQcmdZViewItemQQcategoryZ33581QQihZ013QQitemZ230158549745QQrdZ1QQsspagenameZWD1V Quote Link to comment Share on other sites More sharing options...
Bchappy Posted September 9, 2007 Share Posted September 9, 2007 I would have to say(sorry to bust your bubble) most definitely not. Save up and get the real deal, money spent once in the right direction is much better than twice in a detour. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 9, 2007 Share Posted September 9, 2007 I wouldn't purchase that kit for a 240Z. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted September 9, 2007 Share Posted September 9, 2007 I use the similar kit from MSA. I use them on the street and I was able to keep my outside edge on the fronts from wearing prematurely. I think they add enough negative for spirited street use on a lowered car. My tire temps are usually slightly warmer towards the inside after a hard run on country roads. I measured -1.5 and -1.3 on my front camber after maxing these bushings out. I used a level floor, a level on the rim edges, and trig. to calculate the camber angles. My car is also lowered by 1" from stock. Quote Link to comment Share on other sites More sharing options...
benitoz Posted September 10, 2007 Share Posted September 10, 2007 I have a set I will sell never used, I ended up using azc susp. so I have no use for them let me know if you want them. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 10, 2007 Share Posted September 10, 2007 I have a similar to the MSA setup in the front with relocated front suspension pivot points, allowing me to run -3 to -1.5deg camber. I like them for my budget. Mario Quote Link to comment Share on other sites More sharing options...
