tkach Posted September 11, 2007 Share Posted September 11, 2007 Here is my problem I need to find a battery that is fairly externally small in order to “hideâ€. However after hours of searching I cannot seem to find the information I am looking for. I need to know how much power output I need from my battery in order to crank my stock compression 350 sbc. As to what I understand after cranking I really have no need for the battery as my alternators output should be more then enough to supply power for all my needs. I’m running almost no accessories. But I do need enough power to allow maximum output for my hEI ignition box and dizzy. So how small can I go? What are my baseline numbers that will give me the power I need? Thanks for the help ! Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted September 11, 2007 Share Posted September 11, 2007 odyssey is your simplest choice EDIT - i have no specs to recommend for you, as in my quest i went with a 800 CCA optima. Quote Link to comment Share on other sites More sharing options...
tkach Posted September 12, 2007 Author Share Posted September 12, 2007 e_racer1999 thanks for the reply. The 680 CCA odyssey is the right size and seems to put me on the right track however I cant find the specs I need ie how many CCA's do i need to get my car fired up. I'd like to get just enough to do the job correctly and consistently. Quote Link to comment Share on other sites More sharing options...
dustin280zx Posted September 12, 2007 Share Posted September 12, 2007 I'm just curious, but is "hiding" the battery just for looks or is there a rule your trying to get by? 680cca should be fine for a stock compression motor. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted September 12, 2007 Share Posted September 12, 2007 ^agreed. only reason i went with a 800 CCA is a combination of the 10.5:1 CR and the fact that the battery is moved way in the back. it's on an L6, but it's more power than necessary. Quote Link to comment Share on other sites More sharing options...
jt1 Posted September 12, 2007 Share Posted September 12, 2007 I've got a 680 odyssey in my car. It cranks my 10.5:1 355 with no problems at all. Been in for over three years now. John Quote Link to comment Share on other sites More sharing options...
tkach Posted September 12, 2007 Author Share Posted September 12, 2007 thanks all . as far as why I am trying to hide the battery its mainly for looks. I relocated the battery to the rear but now need more space so id like to move it into the small compartments behind the seats and try it as stock looking as i can. so the CCA # is really important to me as that opens up more options for me. Quote Link to comment Share on other sites More sharing options...
deja Posted September 12, 2007 Share Posted September 12, 2007 thanks all . as far as why I am trying to hide the battery its mainly for looks. I relocated the battery to the rear but now need more space so id like to move it into the small compartments behind the seats and try it as stock looking as i can. so the CCA # is really important to me as that opens up more options for me. If you're putting it int he passenger compartment Odyssey is your only choice. Standard batteries out gas some nasty fumes, Odyssey batteries don't. Quote Link to comment Share on other sites More sharing options...
tkach Posted September 12, 2007 Author Share Posted September 12, 2007 great it seems my mind is made up Odyessy it is, can anybody suggest a good online dealer ? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted September 12, 2007 Share Posted September 12, 2007 I think the optimas are also gas free and contain no acid. There are people who run race batteries in their street cars. I forget the name but I think Summit sells them. They are half the size of the optimas and oddyses. But they also have half the capacity of the optimas and oddyses. If you live in a good weather state, keep you engine in good tune and don't mind replacing the battery every few years, then the race batteries might work for you. If you are like me and want the battery to last for 5+ years and always have enough juice to start you in any kind of weather, then get a full sized battery. That extra capacity means they can degrade longer before they have to be replaced. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted September 12, 2007 Share Posted September 12, 2007 I think the optimas are also gas free and contain no acid.. optimas are gel cell, but if they over charge they do emit hydrogen gas, which is why they are still required to be placed in a box if they are in the passenger compartment for sanctioned racing Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted September 12, 2007 Share Posted September 12, 2007 This thing is tiny: http://www.westcobattery.com/miata.html Not sure if it has the CCA to get you going, though. Definitely a fair weather battery in any case. - Greg - Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted September 12, 2007 Share Posted September 12, 2007 optimas are gel cell, but if they over charge they do emit hydrogen gas, which is why they are still required to be placed in a box if they are in the passenger compartment for sanctioned racing I didn't know that. Good info. Back to the original post, a battery is still needed once the alternator is turning to smooth out voltage spikes as things turn on and off. Even a small battery will work in that regard. Quote Link to comment Share on other sites More sharing options...
tkach Posted September 13, 2007 Author Share Posted September 13, 2007 I love all this info. I didnt know about the hydrogen gas thats pretty spiffy. Correct me if I am wrong here but even being placed in box will not comply with most sanctioned racing unless the box is vents to the extriror? Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted September 13, 2007 Share Posted September 13, 2007 ^not always necessarily true. i don't have access to the rules ATM, but i think that they are here on the site somewhere. you might be able to search and find them. don't know, though Quote Link to comment Share on other sites More sharing options...
