R200 making noise
Hartspank
With a 280ZX being so easy, I'd just pull the whole diff. What kind of noise are you hearing? Does it match up with anything on these pages?
http://www.ringpinion.com/ContentFrame.aspx?FilePath=Content%2fHowTo%2fGeneralInfo%2f%2fDiagnosing_Noise_(Part_1).inc
http://www.ringpinion.com/ContentFrame.aspx?FilePath=Content%2fHowTo%2fGeneralInfo%2f%2fDiagnosing_Noise_(Part_2).inc
Spiders aren't doing anything at all when you're driving straight, they're just along for the ride. It's just ring and pinion until you turn. From the sound of it you'll be needing to pull the diff anyway. I'd suggest you get another one and swap it in, as rebuilding these things is fairly expensive and a good used one is dirt cheap. You should have a 3.90 gear ratio if your ZX is non-turbo.
This is all assuming that this is a diff noise and not something else, of course...
