nbesheer Posted September 20, 2007 Share Posted September 20, 2007 Okay so every now and then when I push my clutch in it will click about half way, it's a metallic click. it's been doing it for the past two weeks now and it's really bugging me, usually it will only do it for a few days. I'm full of clutch fluid and when I press the clutch in really fast I either don't hear/feel the click or it doesn't do it. Any ideas on what I should do ? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 20, 2007 Share Posted September 20, 2007 Is it coming from the pedal, or the transmission, or what? If you feel it through the pedal I'd suspect that the hole in the pedal is all oblonged out and the pin that goes through it is probably all chewed up too. You can get a new pin and weld the hole closed if that is the case. Make sure you have some grease in there too... Quote Link to comment Share on other sites More sharing options...
nbesheer Posted September 20, 2007 Author Share Posted September 20, 2007 yeah it's coming from the pedal. I'll look in my haynes manual to get a better picture of what your talking about. Quote Link to comment Share on other sites More sharing options...
2126 Posted September 25, 2007 Share Posted September 25, 2007 The clicking may also be coming from the pedal return spring where the spring hooks over the tab on the pedal....try a little grease, it may go away! Tom Quote Link to comment Share on other sites More sharing options...
