Challenger Posted September 24, 2007 Share Posted September 24, 2007 Just look at the way it's on, it's not that hard to take off in most cases, i'd assume (unless someone replaced and glued them on) Or welded. Anyone have ideas on how to reattach the snaps to the inside of the drip rail trim? Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted September 24, 2007 Share Posted September 24, 2007 Lift and twist, i have removed two sets like this is 5 minutes total. Quote Link to comment Share on other sites More sharing options...
bjhines Posted September 24, 2007 Share Posted September 24, 2007 The metal pinch welded flange is a major structural component for the roof. Cutting it off compromises the roof in a rollover. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted September 24, 2007 Share Posted September 24, 2007 The metal pinch welded flange is a major structural component for the roof. Cutting it off compromises the roof in a rollover. Absolutely correct. Some people go so far as to use some welding stick under the cut out to provide more support/stiffness when welding the panels together, but I firmly believe that if one were to remove the rails, one should have at least a roll bar installed. Not a big fan of cages on the street...but then I sit tall and I'd be rapping my head on one every time I took a curve or turn a little too fast.... Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted September 25, 2007 Share Posted September 25, 2007 If you can't get the rails off by hand, try a can opener with the wide flat side, put masking tape around that end so not to scratch and do a small amount at a time....I got mine off with out it, doing the twisting method spoke of above, but have used the can opener on lots of older cars... Quote Link to comment Share on other sites More sharing options...
