RB25DET Gearbox on a L28
DJ Nexxus
Thanks guys, but I am a bit confused still, if the Z31 is the RB25 Transmission what is the RB26DETT Transmission?....and what is the Z32 tranmisson, thanks......Oh and the link gave ALOT of usefull info!
The 83 turbo z31 as well as the z32 and RB25DE equipped skyline models share the same transmission called the FSR30A. The transmission comes in both 2WD and 4WD versions, so it's possible that the earlier GTRs came with the same transmission, but the 4WD is bulkier and has a diff pan for front differential fluid if i'm not mistaken.
The later GTRs came with a Getrag 6 speed
Do you mean 88-89 turbo Z31, z32 (turbo and NA), and RB25DET skylines?
sorry yes, you are correct. I mixed it up with the 83 T-5. Thanks for clearing that up, I'll correct my post.
EDIT: looks like i can't edit my post. oh well, the info is now in the thread. thanks for the correction!
