Mike C Posted November 13, 2002 Share Posted November 13, 2002 It will fit, but you will be better off with 4" backspacing. I had 14x7 Autodrags on my car with 3 5/16" backspacing. They rubbed on the drivers side, but that is partially because of a previous repair to the lip. Th 16x7 I have now are 4" bs. Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted November 13, 2002 Share Posted November 13, 2002 So whats the max backspace you can use with 15" wheels and STOCK struts in the front and rear? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 13, 2002 Share Posted November 13, 2002 thanks Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 13, 2002 Share Posted November 13, 2002 A lot depends on the diameter of the wheel and the OD of the wheel tire combo. With 15's I would guess 4", with 16's 4 1/2" and same with 17's. You can modify the rear perch and uses shortened 2+2 springs and get a 245 50 16 on the rear with 5" bs. Your best bet is to test fit a wheel and tire combo and make measurements from there. Not all cars are the same (witness my problem with drivers side rear.)Join a Z car club locally or just try and find a member here near you who will loan you a couple of hours and a wheel/tire to test fit. If you would fill out a profile, people would know what part of the country you are in. You should also post what year your car is also since in some cases that can make a difference. Quote Link to comment Share on other sites More sharing options...
Guest NOSZCAR Posted March 21, 2003 Share Posted March 21, 2003 Hey JasonK if you weren't such a dumb ass you would know that answer. JD Quote Link to comment Share on other sites More sharing options...
Mudge Posted March 22, 2003 Share Posted March 22, 2003 The suggested back space is 1/2 rim width + .5" Quote Link to comment Share on other sites More sharing options...
