germanz Posted October 20, 2007 Share Posted October 20, 2007 Hello, is there any information about the theory of ignition advance map ? Here is my project. L24 wit 10:1 compression + valve job 290 degree cam Triple weber (45) Megajolt with Edis 6 (with MAP) Question are: - total advance ? - influence of fuel mixture - influence of load ? - what is ideal for idle ? - what is ideal starting the engine ? Probably I can convert a megasquirt map. I've found a lot of information here http://forums.hybridz.org/showthread.php?t=113165 Many Thanks in advance Rainer from Germany Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted October 20, 2007 Administrators Share Posted October 20, 2007 is there any information about the theory of ignition advance map ? There is plenty of opinion and theory on the topic. Volumes have been written. Here's a starting guide... Bottom line, give the engine what it likes. On a dyno, most modern unmodified engines will reach mean best torque (MBT) before they begin detonating. At that point, adding more advance is useless (and more stressful), and power will begin to fall. Eventually detonation will set in. However, some engines are detonation limited and some timing value below that threshold will typically produce MBT. If you find more torque beyond detonation, its an indication that only a portion of the cylinders are detonating, but its still 'unsafe'. Give the engine what it likes. At idle, good timing will generate good vacuum. Give it what it likes. Fuel mixture effects the rate of burn, so it can have an influence on 'optimal' timing. Dyno will show MBT. Give it what it likes. Lighter loads decrease the dynamic comp. ratio, causing a slower burn rate. More advance will prove 'better' with light loads. Fuel economy, response, and a dyno will help guide you with this. Give it what it likes. Many engines will start anywhere between 0 and 20 degrees. Again, give it what it likes... you'll know. You will usually find that there is a 'window' of MBT over several degrees of timing. Choose the lesser advance. In fact, slightly 'under' the window, with a slightly richer mixture often produces very similar MBT, with less stress. Never run more advance than required to get you to MBT or knock threshold. Tune. Tune. Tune... and don't forget to give it what it likes. Quote Link to comment Share on other sites More sharing options...
germanz Posted October 21, 2007 Author Share Posted October 21, 2007 Many Thanks for your advise Ron, O.k the dyno will give clearness. Unfortunately my weber have to be tuned in the same time. But I'm still interested in maps from other non turbo project. Cheers Rainer Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted October 21, 2007 Share Posted October 21, 2007 There is plenty of opinion and theory on the topic. Volumes have been written. Here's a starting guide... Bottom line, give the engine what it likes. On a dyno, most modern unmodified engines will reach mean best torque (MBT) before they begin detonating. At that point, adding more advance is useless (and more stressful), and power will begin to fall. Eventually detonation will set in. However, some engines are detonation limited and some timing value below that threshold will typically produce MBT. If you find more torque beyond detonation, its an indication that only a portion of the cylinders are detonating, but its still 'unsafe'. Give the engine what it likes. At idle, good timing will generate good vacuum. Give it what it likes. Fuel mixture effects the rate of burn, so it can have an influence on 'optimal' timing. Dyno will show MBT. Give it what it likes. Lighter loads decrease the dynamic comp. ratio, causing a slower burn rate. More advance will prove 'better' with light loads. Fuel economy, response, and a dyno will help guide you with this. Give it what it likes. Many engines will start anywhere between 0 and 20 degrees. Again, give it what it likes... you'll know. You will usually find that there is a 'window' of MBT over several degrees of timing. Choose the lesser advance. In fact, slightly 'under' the window, with a slightly richer mixture often produces very similar MBT, with less stress. Never run more advance than required to get you to MBT or knock threshold. Tune. Tune. Tune... and don't forget to give it what it likes. I should get T-shirts made that say "Give it what it likes":lmao: Quote Link to comment Share on other sites More sharing options...
MONZTER Posted October 21, 2007 Share Posted October 21, 2007 Maybe this thread will help. Some of us posted our Tec 3 tables. My car is also a L-24, but my head is pretty modified so my timing might seem a little less than most. http://forums.hybridz.org/showthread.php?t=122406 Best Regards Jeff Quote Link to comment Share on other sites More sharing options...
germanz Posted October 22, 2007 Author Share Posted October 22, 2007 Hello Jeff, Many thanks, my haed looks not that differen't. Does it mean that I have to add 15 degree to each value in that table ? 45 degree advance sounds quite high. http://album.hybridz.org/showphoto.php?photo=14997 Cheers Rainer Quote Link to comment Share on other sites More sharing options...
MONZTER Posted October 23, 2007 Share Posted October 23, 2007 Hi Rainer, Those are my actual timing numbers per RPM and MAP points. The head has small 36cc chambers so the burn is very fast. A few degrees is probably need to be added for a stock N-42 head Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted October 23, 2007 Administrators Share Posted October 23, 2007 Rainer, A general rule of thumb... better chambers require less advance to reach MBT. The factory (L-series) chambers are not terribly impressive... so they respond well to more advance than a modern engine. On the other hand, Monzters chambers are a thing of beauty. That is largely, if not entirely, why his timing numbers are modest. On a bone stock 8.3:1 L-series, total timing will probably be in the 38-40 degree range (on premium US fuel). You have more compression and different gas... you will likely find different results. Any map you use/copy should be thought of only as a start point. You must test & tune. Quote Link to comment Share on other sites More sharing options...
germanz Posted October 24, 2007 Author Share Posted October 24, 2007 Thanks for all your help, I have no experience with megaquirt. But how to read Jeff's Map ? Do I have to add the 15 degree initial advance ?Or what does it mean. Cheers Rainer Quote Link to comment Share on other sites More sharing options...
MONZTER Posted October 25, 2007 Share Posted October 25, 2007 Rainer, Ignore the initial advance number, that is for start-up only. Just look at the numbers on the chart. Also, please remember what Ron said, every configuration and every car will be different. Please use the chart as a reference only. Best regards Jeff Quote Link to comment Share on other sites More sharing options...
