the theory if ingnition mapping ?
germanz
Hello,
is there any information about the theory of ignition advance map ?
Here is my project.
L24 wit 10:1 compression + valve job
290 degree cam
Triple weber (45)
Megajolt with Edis 6 (with MAP)
Question are:
- total advance ?
- influence of fuel mixture
- influence of load ?
- what is ideal for idle ?
- what is ideal starting the engine ?
Probably I can convert a megasquirt map. I've found a lot of information here http://forums.hybridz.org/showthread.php?t=113165
Many Thanks in advance
Rainer from Germany
  • Administrators
There is plenty of opinion and theory on the topic. Volumes have been written.
Here's a starting guide...
Bottom line, give the engine what it likes.
On a dyno, most modern unmodified engines will reach mean best torque (MBT) before they begin detonating. At that point, adding more advance is useless (and more stressful), and power will begin to fall. Eventually detonation will set in. However, some engines are detonation limited and some timing value below that threshold will typically produce MBT. If you find more torque beyond detonation, its an indication that only a portion of the cylinders are detonating, but its still 'unsafe'. Give the engine what it likes.
At idle, good timing will generate good vacuum. Give it what it likes.
Fuel mixture effects the rate of burn, so it can have an influence on 'optimal' timing. Dyno will show MBT. Give it what it likes.
Lighter loads decrease the dynamic comp. ratio, causing a slower burn rate. More advance will prove 'better' with light loads. Fuel economy, response, and a dyno will help guide you with this. Give it what it likes.
Many engines will start anywhere between 0 and 20 degrees. Again, give it what it likes... you'll know.
You will usually find that there is a 'window' of MBT over several degrees of timing. Choose the lesser advance. In fact, slightly 'under' the window, with a slightly richer mixture often produces very similar MBT, with less stress.
Never run more advance than required to get you to MBT or knock threshold.
Tune. Tune. Tune... and don't forget to give it what it likes.
I should get T-shirts made that say "Give it what it likes":lmao:
  • Administrators
Rainer,
A general rule of thumb... better chambers require less advance to reach MBT.
The factory (L-series) chambers are not terribly impressive... so they respond well to more advance than a modern engine. On the other hand, Monzters chambers are a thing of beauty. That is largely, if not entirely, why his timing numbers are modest.
On a bone stock 8.3:1 L-series, total timing will probably be in the 38-40 degree range (on premium US fuel). You have more compression and different gas... you will likely find different results.
Any map you use/copy should be thought of only as a start point. You must test & tune.
Rainer,
Ignore the initial advance number, that is for start-up only. Just look at the numbers on the chart. Also, please remember what Ron said, every configuration and every car will be different. Please use the chart as a reference only.
Best regards
Jeff
