idylan123 Posted October 20, 2007 Share Posted October 20, 2007 has anyone ever use these? and do they replace the dash? or just go over it? any pics? http://www.blackdragonauto.com/Features/Z/ZDBC.htm Quote Link to comment Share on other sites More sharing options...
fhptom Posted October 20, 2007 Share Posted October 20, 2007 I would say that unless you got real lucky and found a dash w/o cracks or spent the big bucks on buying a complete new one almost everyone has one of those in there car. At least I have in every first gen car I have had. It is just a matter if you want the full or half cover. Your choice. Tom Quote Link to comment Share on other sites More sharing options...
idylan123 Posted October 20, 2007 Author Share Posted October 20, 2007 okay thanks. but is it just like a snap on cover? or what? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 20, 2007 Share Posted October 20, 2007 idylan123 said: okay thanks. but is it just like a snap on cover? or what? Some people velcro it on, but it's normally installed with silicone to "glue" it down. There are some drawbacks, on some Zs it makes it really hard to get the gauges out the "easy" way. Mario Quote Link to comment Share on other sites More sharing options...
idylan123 Posted October 20, 2007 Author Share Posted October 20, 2007 where can i get the "rug" cover ones? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 20, 2007 Share Posted October 20, 2007 "Dashmat" makes them. Just go to a place where they sell them and they should be able to order it. Mario Quote Link to comment Share on other sites More sharing options...
nbesheer Posted October 21, 2007 Share Posted October 21, 2007 Here is a picture of mine, http://img.photobucket.com/albums/v505/snsforums/My%20Car/DSCF0275.jpg?t=1192928606 This is just chillin' on there I didn't glue it down or anything, but if I were you I would get the half dash cap because it will fit better, also even if it doesn't line up that well it will always look better then a carpet dash, at least in my opinion Quote Link to comment Share on other sites More sharing options...
TONY C Posted October 21, 2007 Share Posted October 21, 2007 I have a full cover on mine. I used 2 full tubes of silicone and after about 6 months it started to come loose. Took me about 10 hrs to scrape/pull/remove the silicone from the dash but absolutely none of it actually stayed stuck to the cover. I want to put it back on but don't want to have to go thru this again. Has anyone used another kind of glue with good results.? Quote Link to comment Share on other sites More sharing options...
zmaster Posted October 21, 2007 Share Posted October 21, 2007 if the cracks in the original dash are popping up do i have to cut them smooth with the dash for the dash cap to lay down properly? Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 21, 2007 Share Posted October 21, 2007 TONY C said: I have a full cover on mine. I used 2 full tubes of silicone and after about 6 months it started to come loose.Took me about 10 hrs to scrape/pull/remove the silicone from the dash but absolutely none of it actually stayed stuck to the cover. I want to put it back on but don't want to have to go thru this again. Has anyone used another kind of glue with good results.? Jeez, I only used what they sent and the cover was on for a long time. Did you only glue down the edges like the instructions said? It has to be able to move around slightly as it expands and compresses. zmaster said: if the cracks in the original dash are popping up do i have to cut them smooth with the dash for the dash cap to lay down properly? Yea, and you might have to trim some areas on the cover itself. Just keep dry fitting it until it seems to fit alright, then glue it down. Mario Quote Link to comment Share on other sites More sharing options...
inlawZ Posted October 24, 2007 Share Posted October 24, 2007 i have the half cover, and was thinking of using just a glue gun. it should hold, but be easy to peel off and clean off if needed.... any thoughts? Quote Link to comment Share on other sites More sharing options...
het976 Posted October 24, 2007 Share Posted October 24, 2007 My cover was sitting for a while and may have been warped a little, but it did not fit exactly right. I used a heat gun to soften it up and mold it into the guage areas and around the glove box so it fit better. Just don't melt it. Quote Link to comment Share on other sites More sharing options...
