jkgts1 Posted October 20, 2007 Share Posted October 20, 2007 Hi, for those that have done the 2jzgte into a 240/260z how does it handle? I am aware that the 2jzgte is a very heavy motor, and wanted to know how it is around corners. Thanks, jgkts1 Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted October 21, 2007 Share Posted October 21, 2007 Hi, for those that have done the 2jzgte into a 240/260z how does it handle? I am aware that the 2jzgte is a very heavy motor, and wanted to know how it is around corners.Thanks, jgkts1 ( ??? there is a little bit more than just the engine weight in the equation) On standard suspension, probably like a whale with an alcohol problem. uprate suspension(plus power steer) corners like a rat. Might pay to put brakes in as well.you may need to slow it down before you hit the corner. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted October 21, 2007 Author Share Posted October 21, 2007 Sorry, I assumed that the suspension would be done too. I just wanted to find out if the weight problem could be fixed fairly easily. I ask also because I have a 77 Celica that I wanted to put a 7mgte in but I hear it is way to heavy and would have a difficult time making it handle nice. I want to be able to take the Z to the track also, and not just go fast in a straight line. Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted October 22, 2007 Share Posted October 22, 2007 The factory L28 is near the same weight of the 2JZ without the turbo's on it. It should handle just as well as L28 powered S30 especially if you mount the 2JZ against the firewall and as low as possible. Justin Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted October 22, 2007 Author Share Posted October 22, 2007 Awsome, thanks. Quote Link to comment Share on other sites More sharing options...
johnc Posted October 22, 2007 Share Posted October 22, 2007 Given enough time, money, and testing any can be made to handle reasonably well. The Porsch 911 is a classic example. Quote Link to comment Share on other sites More sharing options...
