Replaced T/O Bearing, no motion
Stock 240z, had a loud throw out/clutch release bearing, spent 5 hours changing it yesterday, today I finally start it up, its no good. The car doesn't move with the clutch out in gear. No weird noises. Jack the car up in the rear, prop shaft turns no matter what the gear. Clutch slave is depressing the fork, any gear is selectable with engine running clutch in or out.
I can't figure this one out for the life of me. The engine and trans are bolted flush, there was a clutch in before, so I assume the disk can't fall down, can it? I just lined them up and it went straight in the first try. The only possible thing I could think of is that somehow the clutch fork isn't contacting the throw out, but is that possible?
EDIT: By the way I am using a 1981 5-speed 280zx NA sleeve, but a 240z throw out. Not from a 2+2 though. They looked the same when I installed it. Incase that might matter.
  • 1 month later...
