Zeero Posted October 25, 2007 Share Posted October 25, 2007 Ok guys, so I searched and came up with that a zx will not accept 3" DP. I was looking around the net for options and came across Dr. Gas oval tubing. Would this work for a DP and full exhaust to help with clearance? Go from round to oval(they have these pre-made) and continue along in oval? Any input is appreciated! I was looking for round to oval because I have an exhaust tip that is oval. Trying to find best way to fit. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted October 26, 2007 Share Posted October 26, 2007 I have 3" exhaust on my 280zxt. Coming out of the turbo is 2 1/2". But it flares out to 3" and then all the to the back of the car. You should not worry about exhaust clearance on 280ZX because the transmission tunnel is bigger than the earlier Zs. The exhaust runs over the rear crossmember. Not like the earlier Z. You don't need oval pipes for the ZX. Do a search for Jeff P's down pipe. Quote Link to comment Share on other sites More sharing options...
phil280zxt Posted October 26, 2007 Share Posted October 26, 2007 Here's a link to Jeff's exhaust system page. Vinhzxt and I were lucky enough to get in on Jeff's last group buy. Three inch is no problem on the ZX. http://www.angelfire.com/extreme/280zxt/page11.html Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted October 26, 2007 Share Posted October 26, 2007 Something to think about oval tubing: how do you plan to bend the oval tubing? You can't just buy a bunch of u bend oval tubings and cut up to make your exhaust. It won't work as easy as the round tubes. Quote Link to comment Share on other sites More sharing options...
strangethursday Posted January 9, 2008 Share Posted January 9, 2008 VinhZXT said: Something to think about oval tubing: how do you plan to bend the oval tubing? You can't just buy a bunch of u bend oval tubings and cut up to make your exhaust. It won't work as easy as the round tubes. That's why you just cut it up & piece it together all JDM like Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 9, 2008 Share Posted January 9, 2008 strangethursday said: That's why you just cut it up & piece it together all JDM like That's round tubing they do that to...and unless you are VERY good at sizing, those kind of bends almost always flow poorly due to a reduction in cross section somewhere (usually multiple places) along the "bend". It's a function of the culture as well. You got straight tubing, and a chop saw, you can make a bend. If you have access to mandrel bends for anything, you are better off cutting them and piecing it together as you will have a better 'bend' than making a bend out of angle and wedge-cut straight tubing. I dropped 1psi of restriction going from my 'JDM' IC Piping to a mandrel-bent set. And that was on tubing that was properly deburred on each weld before going to the next piewedge... Quote Link to comment Share on other sites More sharing options...
LT280z Posted May 15, 2008 Share Posted May 15, 2008 I was looking into Oval type tubing and Drgas.com has all the answers. They dont show alot of bends on their site but if you call them they can pretty much do it all. They also have really cool mufflers that are only like 2.5" thick. Quote Link to comment Share on other sites More sharing options...
rdelat Posted June 19, 2008 Share Posted June 19, 2008 check this out all 3.0 mandrel bent he builts piping kits Quote Link to comment Share on other sites More sharing options...
primadonna z Posted June 19, 2008 Share Posted June 19, 2008 Here's a link to the oval exhaust system that I built for Zwolf. You will need to scroll down to the 6th post. http://forums.hybridz.org/showthread.php?t=117195&highlight=primadonna+exhaust&page=2 Workks great, sounds a little different, and it's Hot. The oval tubing increases the concentration point of heat on the floor boards so it tends to be hotter inside. Oh...get your pocketbook out. Quote Link to comment Share on other sites More sharing options...
