Guest DeadlyImpulse07 Posted October 26, 2007 Share Posted October 26, 2007 I just picked up my 280z, it hasnt run in quite sometime, the radiator has a leak and instead of buying the standard replacement radiator my father suggested I use a radiator called a 'Desert Cooler', something about a 5 row cooler?. Any one know if this is any good and where I can pick one up? Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
spacecase70 Posted October 26, 2007 Share Posted October 26, 2007 look into getting a radiator for a 78 280 at the J/Y and make sure it comes out of a car w/ AIR and maybe even an auto transmission. I live in the desert in so california and it gets just as hot here as it does in tx... i used to live in dallas. anyway that is what i am using and i dont have any heating problems, just dont forget to change your hoses and thermostat before you get to rockin! Quote Link to comment Share on other sites More sharing options...
Guest DeadlyImpulse07 Posted October 27, 2007 Share Posted October 27, 2007 I dont have a heating problem, but this is a high performance coller which is what im looking for. thanks though! Quote Link to comment Share on other sites More sharing options...
rztmartini Posted October 29, 2007 Share Posted October 29, 2007 if you don't have a heating problem, then i dont think you will need a 5 row rad. AZC sells a nice direct fit aluminum unit, MSA may have a drop in aluminum rad as well. A 5-row rad will be heavier than a 1 or 2 row rad as well...but if you plan on a blown V8 or a high strung turbo motor and are intending to endurance/road race, the 5 row would probably be a better choice. Quote Link to comment Share on other sites More sharing options...
Clifton Posted October 29, 2007 Share Posted October 29, 2007 1 Fast Z sells them too. http://bandmzcars.com/RadiatorPage.html Quote Link to comment Share on other sites More sharing options...
